Configurator 360 Forum (Read Only)
Welcome to Autodesk’s Configurator 360 Forums. Share your knowledge, ask questions, and explore popular Configurator 360 topics.
Confusion with colours
1 REPLY 1
matthewweake1
1021 Views, 1 Reply
In my Inventor iam I have colour over rides set by iLogic and a form that I use. The colours of the various instances are changed according to a parmater in the assembly.
When I upload the iam I loose the forms (OK with that) but the colours are taken just from the part files.
Is there a way to override the part colours in the assembly or is that what is meant by limitations of not implementing the material library?
I guess I could get iLogic rules to force the part colours to change rather than just the instance. Would these display like I want?
I like the idea of this Configurator 360. Lots of potential!
Matthew Weake
matthew.w@cadpro.co.nz
+64 9 302 4028
1 REPLY 1
Hi Matthew,
Configurator 360 currently does not honor color overrides applied at the assembly level. We'll prioritize and schedule this for a future update. For now, you'll need to change the part colors as you suggest and that should work fine.
Sanjay-
Sanjay Ramaswamy
Product Manager
