Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
problem error unknown
8 REPLIES 8
Message 1 of 9
3115 Views, 8 Replies
hi everybody
I need help, I Mudbox 2013 all ok the installation, but I can not start because there is an error that prevents me:
"An unknown error has occurred while performing the operation.
We are sorry for the inconvenience."
here's a picture: http://tinypic.com/r/2v9q25s/5
i have acer aspire 5755g
intel core i7-2630QM 2GHz
with turbo boost up to 2.9GHz
NVIDIA GeForce GT 540M
6GB Memory DDR3
use windows 7 64 bit
I hope you help me
8 REPLIES 8
Message 2 of 9
I have the same exactly error and I can<t find a solution.
Message 3 of 9
hello
thanks for the reply, however, I tried it with Mudbox 2009 and it works.
try it
Message 4 of 9
I solved it in an other way. The reason was the driver of my graphic card (320.49 Gtx 760), I installed the next one (a beta) and now everything work fine.
Message 5 of 9
that beta? give me url that I can download it please
Message 6 of 9
Message 7 of 9
I'm downloading now hope it works
Message 8 of 9
oh yeaaaahhhhhhh!!!!!! WORKING Smiley Very Happy  thank you very much max_monette
Message 9 of 9
jokerbot
In some cases, the problem may be incorrect indications paths to system folders Mudbox (Windows-> Preferences-> Paths). For example, if part of the path will have Cyrillic: [E 😕 User / Иван / Autodesk / Mudbox 2015/data] - Mudbox can produce the type of error:
"An unknown error has occurred while performing the operation. We are sorry for the inconvenience."
Try changing path that the words had only Latin. Hopefully helps. Good luck.)).
