Area :: Header
Maya LT is on Steam
Now with "Send to Dota2" export!
Discussion Groups
Community Help
Active Member
aralfirin
normal map problem
6 Views, 5 Replies
02-20-2009 12:26 PM
I posted this in the maya forum but thought I would get more help here.
So here is may problem, I did a normal map in mudbox 2009 and in maya there are seams at some UV intersections. The normal map is seamless and was edited in photoshop to be sure, it was then renormalise withe the Nvidia plugIn.
thanks.
Please use plain text.
Distinguished Contributor
skycastleMud
Re: normal map problem
02-20-2009 02:34 PM in reply to: aralfirin
So you baked the normal map in Mudbox 2009 using the Maya preset?
Then without any edits display the map inside Maya and you see a seam?
Active Member
aralfirin
02-20-2009 02:57 PM in reply to: aralfirin
Yes that's it. But in another scene I don't understand why, there is no seam. Could it be my lighting that creates that problem?
thanks
MasonDoran
02-21-2009 06:12 PM in reply to: aralfirin
Its just the reality of normal maps. In your case you chose a bad spot for the seam. The work around is to choose the default blue and paint over the seams.
DarthWayne_1
02-21-2009 06:43 PM in reply to: aralfirin
There is an old trick where you can pait over just the green and red channels of your normal map in photoshop to get rid of any seams. 99 times out of 100 it works perfectly for problem map seams.
Wayne...
www.MudboxHub.com Independant Mudbox User Forum
www.DashDotSlash.net - personal site
Active Member
aralfirin
02-23-2009 03:02 AM in reply to: aralfirin
Thanks everyone for your help. Wayne, I tried the photoshop tip and it didn't work but I changed my lights placements and there is no apparent seam now. So can someone explain me why this happened and how to avoid it?
thanks
