quck question how can i add custom base meshes to the same list that shows when mudbox starts?(the one here you base head,car,bull,man,reptile etc)
thanks
Kinglaw
hello, as RobinBall6995 suggested, please try to put your files into C:\Program Files\Autodesk\Mudbox 2014\Meshes
and reload mudbox.
The correct install directory is Documents\Mudbox\MudboxCommunity\Downloaded\Meshes
Just delete the xml file as its not needed. If you download the basemeshes through mudbox itself in the Community tab, it will install it automatically and add it to the list as well.
