Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
bump map preview error.
5 REPLIES 5
203 Views, 5 Replies
I get this error only my imported models.
5 REPLIES 5
What is the error?
Are you using Service Pack 1?
What are your system specs please?
Standart base models no have problem , bump map very smooth looks great.
But i import model then created some maps , only bump get this error , like thresholded.
My model have 8 triangle poly. UV no overlapped.
thanks.
System:
q9450
4gb
9600 gt
Xp pro 64
Sp1
area.autodesk.com/forum/Autodesk-Mudbox/my-tips-tutorials-workflows/mudbox-2k9-sp1-normal-map-preview-demo/
Follow through the process above just to double check that each step in the process is correct. Also next thing to check is that your uv's are ok and allocated enough space for the details you are trying to add. (Inlcluding your base mesh sometimes helps as we can all overlook things once in a while.) If its none of these then the investigation continues.
Wayne...
Thanks for reply ,
I understand problem , if model size very little than Mudbox's standart base meshs like a basic head , bump map looks threshold ed or very high depth like a my screen cap.
Mudbox's internal scale tool doesn't work , for example i re size my model to "basic head" scale , I get again this problem.
When I re size to basic head's size my model with modo , then import to mudbox , no problem.
Thanks for reply ,
When resizing a model in mud export after resizing then import again. This way mud remember the new scale and not the old one.
Wayne...
