Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Community Help
New Member
Arod529
Texture consistancy from Mudbox to 3dsMax
99 Views, 3 Replies
05-24-2012 08:19 PM
So I have a quick question. I've begun introducing mudbox into my workflow and for this particular model I using it simply as a texturing tool as the model is too simple to need sculpting. Anyway, when I transfer the textures I've painted into 3ds Max, the display of color is not consistent. Is there some way to set up mudbox lighting so that it reflects what it will look like in 3ds Max? Here are a couple of pics:
Mudbox texture: Looks Good (color how I want in the end result)
http://farm8.staticflickr.com/7238/7265464018_c334806626_b.jpg
3ds Max Texture: Looks Bad (appears to more accurate to actual color of the texture image. Looks like there are some funky texture seams too.)
http://farm9.staticflickr.com/8024/7265464128_cee91ed64d_b.jpg
Thanks.
Please use plain text.
*Expert Elite* | Moderator
cg_oglu
Re: Texture consistancy from Mudbox to 3dsMax
05-24-2012 10:56 PM in reply to: Arod529
have you turned on the linear workflow in max..?
are those seams visible in the render or only in the viewport..?
http://www.linkedin.com/pub/christoph-schaedl/6/558/73b
*Expert Elite*
05-25-2012 03:06 AM in reply to: Arod529
Yeah I suspect it's gamma. I've had that as well. The textures come in with gamma set to 1 and it should be 2.2 I think. I don't really know too much about it, I never have anything to do with gamma when working on games. But 2.2 seems to be the same.
And I don't think that's a seam as such, I think it's the default lighting second light which gives a really harsh rim light effect. Change the viewport to 1 light instead of 2 and it should go away.
New Member
Arod529
05-31-2012 10:33 AM in reply to: Arod529
First, I had it on the default 2 light setting. I changed it 1 and it fixed the weird dark bands. It also properly displayed my normals, as another model I had been working on was actually inside out, but didn't display that way.
Second, it is definitely the gamma. I have been doing some experiments, and believe I had set up the gamma proper as I was reading in the 3ds Max help. By default the input and output gamma was set to 2.2.
According to what I read, I was supposed to set the input gamma to whatever the texture files' gamma was. I have confirmed that the images I have painted in mudbox are saved with a gamma of 1, so I set the input gamma to 1. Then I am to set the output gamma to whatever the working/screen gamma that I want to use is, so I left that at 2.2. Unfortunately, though, the textures are still brighter than in mudbox. I have tried all kinds of numbers but still can't gain consistency. If I turn off gamma correction in the 3ds Max settings, then the color display is identical. This would be fine if all I was working with was Mudbox and 3ds Max, but it's not.
(I have also experimented with cryengine3 a bit, and believe that the engine also probably runs on 2.2 gamma settings, as the textures are a bit bright and pinkish.)
Also I'm not sure how to adjust everything to work with gimp. I couldn't find any gamma settings, and the color seems to be slightly on the orange side.
I tried working with the tone mapper filter in mudbox, as I couldn't find any gamma settings in there either, which seems counter productive. It doesn't seem to effect the color wheel, however, and the gamma seems to dynamically change depending on how close or far away from the model I am.
Any ideas on how to set up a consistent workflow? Are there settings somewhere in mudbox I am missing? I really need to be able to adapt to whatever environment I may end up working in.
Thanks.
