I have Max units set to meters and the same in Mudbox. Everything is fine when I use the 'send to' feature. But if I export an obj from Mudbox and import it into another program its scale is way off. 14 meters is suddenlt 1400 meters.
Am I just missing something simple here? Anybody have any ideas?
Thanks for getting back to me lads.
I've changed the system units in Max to cm and the same in Mudbox and it seems to be working. I'm taking obj's in from Geomagic so i'll have to rescale those on import to Max but hopefully that'll run smoothly.
I tried fbx and obj and both worked well.
Odd how it doesnt work with metres.
Hopefully it's not an issue now.
Thanks again for that!
P
