I've tested Mudbox 2015 on both generations of Surface Pro and the Lenovo Thinkpad Yoga with the same results as demonstrated in this video.
https://www.youtube.com/watch?v=8H_rdHU3ivY
Also, in mirror paint mode, the mirrored side is 100% color value, the other appears to be in Lighten mode. I've tried with a variety of display drivers available from Intel. Is Autodesk aware of this issue?
Solved by RICKRODRIGUEZ5808. Go to Solution.
Hi Rick, I had take a look to your video link, and I will log a request to our developers to take a look one this issue in 2015 Mudbox, thanks for your precious feedback.
Best Regards
Hi Rick,
This is caused by certain new and Beta Nvidia Drivers with certain graphic cards, have you tried a previous certified driver driver for your graphic card, this could maybe fix the issue until new certified drivers will come live.
The Surface Pro doesn't use NVidia drivers. My system is running the Intel HD display driver published by Microsoft (10.18.10.3431). Can you tell me what driver works?
Happy to report that the latest display drivers from Intel fix the paintbrush bug. It's finally possible to use Mudbox on the Surface Pro 2. https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23885&lang=eng
I'm having the same issue with my laptop.
Is this an issue with mudbox or is this my graphics card?
