Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
MudBox 2015 can't change brush size/strength using B/M key
9 REPLIES 9
Message 1 of 10
kminh
5800 Views, 9 Replies
Hi guys,
I'm using Student Version of MudBox 2015. I'm trying to increase/decrease brush size/strength by holding B/M key and then press Left mouse button and drag up/down but it doesn't seem to work.
Could anyone please tell me if I'm doing something wrong?
Thank you for any insight.
9 REPLIES 9
Message 2 of 10
sergimen2001
in reply to: kminh
This problem could be perhaps your are increasing the size/strengh more than the size of the viewport.Try to save work and close Mudbox, and restart it.
I have various questions about problems in mudbox too here, and have no reponses or help...
I have an youtube channel for 3D learning, including 3DS MAX and Youtube.
https://www.youtube.com/user/sergiomengual
You can leave your questions in my videos comments.
If I can help you with your problem I will response.
Greetings: Sergio.
Message 3 of 10
kminh
in reply to: sergimen2001
Thanks for your response. My brush size/strength is currently very small.
Can you tell me the exact steps you use to increase size/strength? Press and hold M, and then click left Mouse and drag up/down?
Your channel looks very useful to me, thanks!
Message 4 of 10
1896305733
in reply to: kminh
Perhaps it will help ...--> Menu "Windows" -> "Hotkeys" -> Select "mudbox" -> + resetting. My apologies for the translator.
Message 5 of 10
in reply to: 1896305733
same here, the indicator shows up but I cannot adjust it.
When I swith the UI to mudbox (windows-> hotkeys) it works but when using 3ds Max shortcuts it fails to work.
Message 6 of 10
W0ND3RB0Y
You probably already know by now, but im still posting in case others run into this issue.
When using settings for 3D's Max in mudbox, you need to click: Ctrl + Shift + Left Mouse Button to adjust the size by dragging. To ajdust strength, click Alt + Shift + L Mouse Button and once again, drag to adjust the level.
Message 7 of 10
Why when changing the brush size (by holding b and dragging) sometime the increments are small, and sometimes huge, so the brush gets 'lost'?
Message 8 of 10
bahadirdundar
in reply to: kminh
please press ctrl+shift+drag enjoy it 🙂
Message 9 of 10
bahadirdundar
in reply to: kminh
ctrl+shiftr basılı tutarken mausu hareket ettirin.
Message 10 of 10
james.a.mashock
in reply to: kminh
Recently when having this issue. I locked and then unlocked my model. Seemed to do the trick. Hope it works for you.
