Mudbox Forum
Welcome to Autodesk’s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Jagged lines
2 REPLIES 2
823 Views, 2 Replies
Jagged lines
My bump maps have jagged lines and I want them to be clean and sharp. Is there anyway I can do this without increasing the size of the paint layer ( All paint layers are 4k ).
2 REPLIES 2
MatthewDoyleArt
Are you extracting normal maps? If so, have you tried adjusting the settings in the extract operation? Such as enabling Anti-Aliasing? Or are you just saving an actual grayscale bump map from hand painting it in Mudbox? If so, you might have to take it into Photoshop and try some filters to reduce anti-aliasing, but it also largely depends upon the size of the texture, how large the bump pattern is, and how that relates to your UV size.
You could also try a subtle blur of the bump texture in Mudbox - which works like smoothing. Or you could convert your bump to a normal map and extract it using anti-aliasing.
Matthew Doyle
Technical Marketing Manager
Area Blog: Game Dev Blog
Watch me on Youtube: Youtube.com/MatthewDoyleArt
Check out some of my work at: MatthewDoyle.com
in reply to: MatthewDoyleArt
wow that helped quite a bit thanks
