Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Community Help
Active Contributor
Comp wiz
How
20 Views, 8 Replies
04-04-2007 06:19 AM
:confused: How do I transfer a model from Maya to Mudbox and from Mudbox to Maya.
Please use plain text.
Distinguished Contributor
Silva Spoon_1
Re: How
04-04-2007 06:34 AM in reply to: Comp wiz
export and import it as an ".obj" file.
Active Contributor
Comp wiz
Re: How
04-04-2007 08:28 PM in reply to: Comp wiz
When I export the model as an obj. file and try to open it in Maya i get a message that says "unrecognized file type" Please help!!!:mad:
Re: How
04-04-2007 08:42 PM in reply to: Comp wiz
You should read the documentation for Mudbox and Maya before making posts like these..
Make sure you actually change the file format in the export options for Maya. You can't just type in ".obj" and expect it to work.
Active Contributor
Comp wiz
Re: How
04-05-2007 02:45 PM in reply to: Comp wiz
I tryed to change the format to obj. in Maya but it would not allow me to. I have a personal learning addition of Maya. Could this be the problem?
jacquesd_1
Re: How
04-05-2007 02:48 PM in reply to: Comp wiz
I'm wondering if by default the 'OBJ' export plugin is loaded in Maya... Have you checked that one?
Jacques.
Active Contributor
Comp wiz
Re: How
04-05-2007 06:24 PM in reply to: Comp wiz
I have not checked this. how would i go about checking this:confused:
Re: How
04-06-2007 12:48 AM in reply to: Comp wiz
PLE won't let you export to obj if I recall correctly. If you're not planning on buying maya, you might want to consider Blender, which is a free 3D modeling application that can export to obj.
Valued Contributor
Re: How
04-06-2007 04:17 AM in reply to: Comp wiz
window ->settings/preferences->plugin manager
then find objExport.mll and activate it...
and yo have to import .obj file , if you use open you will get unrecognized file type error..
good luck
