Community Classifieds
new software: geometrywiz civil tools - g-labeling
0 REPLIES 0
Message 1 of 1
130 Views, 0 Replies
for AutoCAD 2000i thru 2004 and vertical products.
read more by going here:
http://www.draftteam.com/g-labeling.htm
direct download:
http://www.draftteam.com/g-labeling/g-labeling.zip
direct preview:
http://www.draftteam.com/videos/g-labeling.html
description:
this module of g-labeling includes all the necessary routines to do all the
geometric labeling or annotation.
the data annotation of g-labeling includes powerful routines to write
automatically individual or global form in lines, arcs and areas. In the
dialogue box the data are selected to write down (bearing and distance for
lines, curve length, radius, delta, chord and subtangent for curves). It is
possible to specify in addition area prefix and suffix for each data, height
of text and number of decimal.
g-labeling can detect intersections line-line, line-curve and curve-curve.
the data can be written above or below the curve. by indicating a point
inside a closed area the program writes down the area in the geometric
center of that figure, offering itself additional options to draw up and to
select polygons, to rotate and to move text and to undo.
just by selecting a polygon, g-labeling calculates all the data necessary to
create construction tables instantaneously (bearings, distance, angles,
coordinates and area). two types of tables and options are offered to
indicate number of decimal for each data, numeration of vertices in manual
or automatic form with numbers or letters clockwise and counter-clockwise
form and the option to indicate starting vertex. when generating the curve
table, the program writes down the key and points of flexion in each curve
in global form, recognizing arcs and polylines with curved segments.
regards,
Luis Esquivel
CADDximation Software
0 REPLIES 0
