P O L Y L I N E S P E C I A L I S T 3.20 A N N O U N C E M E N T
HomePage : www.4d-technologies.com/polyline_specialist
Direct Download:
www.4d-technologies.com/polyline_specialist/download/plspec.exe
Polyline Specialist for AutoCAD 2004, 2002, 2000i and 2000
Download now for a free full-featured 30-day trial download.
The Polyline Specialist is a low-cost high-value product that can be
used to fulfill your most common polyline processing needs. Discover for
yourself powerful yet easy to use tools that work with polylines, lines,
arcs, splines etc and help you create, modify convert, process and
analyze polyline data in ways that you never imagined before.
Polyline Specialist is a productivity enhancement tool for just about
any AutoCAD user who needs to work with polyline data at one time or the
other. Polyline Specialist brings to you over 9 man years of programming
and AutoCAD expertise from the developers into a little, cool and nifty
product.
This new V 3.2 edition is 100 % icon menus toolbar, pulldown menu,
command-line and script driven. With this new addition, it is now much
faster than ever to access your tools and this single feature alone can
save you over a hundred or more keystrokes during your work.
Multiple Polyline Specialist interfaces:
- Toolbar pick
- Pull-down menu pick
- AutoCAD command-line
- Automated batch script
Look under the hood carefully. Some tools that you see here may seem to
be already present in your core AutoCAD or in other tools that you may
have used. Don't be misled. In many cases, Polyline Specialist offers
you more possibilities, more options than is possible in ther tools.
Check it out for yourself.
Some of the features of the Polyline Specialist are:
Tool # 1 - [Polyline] - Join 3D polylines
Tool # 2 - [Polyline] - Automated join [2d polylines]
Tool # 3 - [Polyline] - Flexible ways to convert 2D-3D and 3D-2D polylines
Tool # 4 - [Polyline] - Specify a new start point for closed polylines
Tool # 5 - [Polyline] - Single pick add-vertex, delete vertex
Tool # 6 - [Polyline] - Convert zero length to points
Tool # 7 - [Polyline] - Identify & Reverse direction
Tool # 8 - [Polyline] - Distance and angle based weeding
Tool # 9 - [Polyline] - Set zero elevations to nearest non-zero value
Tool # 10 - [Polyline] - Populate zero value elevations by linear
interpolation
Tool # 11 - [Polyline] - Label vertices, Label segments, Fully user
customized
Tool # 12 - [Polyline] - Compute summed lengths
Tool # 13 - [Polyline] - Control polyline linetype
Tool # 14 - [Polyline] - Multiple Pedit
Tool # 15 - [Polyline] - Identify zero elevation vertex
Tool # 16 - [Polyline] - Explode wide polylines, retain width geometry
Tool # 17 - [Polyline] - Place Points/Blocks along vertices
Tool # 18 - [Polyline] - Powerful property based filtering
Tool # 19 - [Polyline] - Offset, Move, Extract, Mirror, Rotate, Stretch
part of polyline
Tool # 20 - [Polyline] - Find direction of vertices
Tool # 21 - [Polyline] - Convert arc segments to linear in many ways
Tool # 22 - [Polyline] - Convert from spline, Convert to spline
Tool # 23 - [Polyline] - Compute detailed statistics
Tool # 24 - [Polyline] - Easy 3d polyline
Tool # 25 - [Polyline] - Express Pedit
Tool # 26 - [Polyline] - Highlight elevation differences
Tool # 27 - [Polyline] - Add/Remove closing vertices
Tool # 28 - [Polyline] - Fillet between two polylines
Tool # 29 - [Polyline] - Offset and delete original
Tool # 30 - [Polyline] - Offset closed polylines INwards / OUTwards
Tool # 31 - [Polyline] - Break crossing objects at end of polyline
Tool # 32 - [Polyline] - Multiple Variable distance measure
Tool # 33 - [Polyline] - Multiple Variable polyline segment offset
Tool # 34 - [Polyline] - Convert lines, arcs, circles to polylines
Tool # 35 - [Polyline] - Offset 3d polylines
Tool # 36 - [Polyline[ - Weed (remove) collinear vertices from polylines
Polyline Specialist development is user-driven. You tell us what you
would like to see in upcoming releases and we try and put them in for
you as soon as possible, sometimes in as little as a few days after your
request is made.
For complete details, visit our Polyline Specialist website on
http://www.4d-technologies.com/polyline_specialist and our homepage
30-day evaluation copy available.
At only US$ 32.95 per license (pay by credit card, PayPal, checks), you
simply cannot go wrong. Attractive multiple license discounts available.
AutoCAD customization for Engineering/Mapping/GIS
Get GeoTools @ http://www.4d-technologies.com/geotools
Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
FREE downloads : http://www.4d-technologies.com/techcenter
