Hello, I'm working on a project to create a cast aluminum globe of the moon, something on the order of 21-24 centimeters in size, that uses data from the LRO to create a highly accurate reproduction. This would be a kickstarter project similar to the 3D lunar map (
http://www.wired.com/2012/02/3d-moon-map/). I've had conversations with a number of metal fabrication companies and they've requested a 3D model (sldprt, igs or stp preferred) of the moon in order to send a price quote - this is a critical element for moving the project forward. I've had conversations with a number of people at JPL and NASA and they've been very supportive, but I need help getting the existing data (see links below) into a file type that the metal fab companies can work with. I'm willing to pay a reasonable amount for someone or a team to help make this happen. Please let me know if you have any ideas on how to move this forward, how long you think it would take and what you think it would cost. Thank you, Chris Data Sets
http://wms.lroc.asu.edu/lroc/view_rdr/WAC_GLD100 (64 ppd should be fine) - this is the leading candidate in terms of datasets, but this is not my area of expertise so I need someone to help figure out what the best starting point is.
http://wms.lroc.asu.edu/lroc/rdr_product_select - home of the LROC data sets
http://imbrium.mit.edu/LOLA.html http://planetologia.elte.hu/ipcd/ipcd.html?cim=virtual_moon_soviet https://3dwarehouse.sketchup.com/model.html?id=8dfb3b57ce5b32506a12484fa9d9be10 Potentially useful related info -
http://selena.sai.msu.ru/Rod/Publications/Rodionova%20ICC2013.pdf
