DraftTeam is a comprehensive set of drafting routines to enhance and
supplement the use of AutoCAD by creating additional functions based on
efficient programming and Visual Lisp object reactors. Numerous utilities
are provided to automate and simplify the execution of many drafting
specific tasks inside of AutoCAD.
The main concept of this AutoCAD add-on is the simplicity and its ease of
use. Designed to provide a simple learning curve, the menu dialog interface
allows you to easily execute functions, complemented by convenient
right-click cursor menu shortcuts.
Some of the commands are:
Just select your lines and arcs and this function will create ALL of your
dimension annotations in one step.
DIMALL
Need a powerful, one step dimensioning system? This one's for you, just
select your closed lightweight polyline or any objects that form a closed
area. There it is! All your associated dimensions created in one step.
DIMAROUND
Do you need to number your doors and designate them with your own naming
convention? Use this command and it inserts a block with a customizable door
name and/or number. You can then easily change the name, position and
working scale of the block at any time.
DOORNUMBER
Convert your lines to walls. Just make a selection of lines whether they
form spaces or not and easily create your walls at a user-defined thickness.
DOUBLELINE
Globally join together all your collinear lines, even those lines on top of
each other, to create new single lines.
GLINE
This is a must have utility. Effortlessly insert, copy, move and adjust all
of your horizontal and vertical bubble grids. If an existing gridline is
erased subsequent bubble items are automatically updated and replaced. Move
an individual bubble and its gridline automatically extends to the proper
location. Simple in its use and intuitive in its execution this demonstrates
the power of reactors.
GRIDBUBBLE
Create your door insertions in a single step. This function will open or
break your walls and from a dropdown list then install anyone of a variety
of standard or user defined door for you. Including many other indispensable
tools such as the ability to flip, move and modify doors with ease.
IDOOR
And more...
Ask us if DraftTeam can be customize or personalize for your standards or
tell us what command(s) would you like to be included...
Visit our web site and download it now...
http://www.draftteam.com
