CAD Managers
Active Contributor
riznasp
Message 1 of 4 (822 Views)
xref and attribute
822 Views, 3 Replies
02-27-2013 12:55 AM
Friends,
I have inserted an xref into my file with an attribute in it. Is it possible to edit the attribute in the xref file without going into the xref file? I hope we can.
Riznas
pendean
Message 2 of 4 (803 Views)
Re: xref and attribute
02-27-2013 05:26 AM in reply to: riznasp
Most likely no, but your question is not detailed enough: more details about the "attribute" would help, like is it in a block or did you simply reference a block with only attributes floating around... .
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
riznasp
Message 3 of 4 (450 Views)
11-24-2013 04:23 AM in reply to: pendean
Hi Dean,
Thanks for your reply. My question was that, instead of inserting title block xref and attribute block into the plot sheet file, can i insert the attribute block into the title block file and then insert the title block file inserted into the plot sheet file. I'll have to insert this xref into may be 100s of files. But if i do so will i be able to edit the attribute without going into the xref.
Riznas
JGerth
Message 4 of 4 (433 Views)
11-25-2013 10:19 AM in reply to: riznasp
riznasp wrote:
Hi Dean,
Riznas
no
Any edits you make to the attribute that's been inserted into the xref title block will be identical across those hundreds of drawings.
Better approach would be to keep doing what you are doing, eg the Xref for stuff that's consistent across all sheets and an attirbute Insert thadisplays the information specific to each sheet.
next step will be to start exploring SheetSet Manager.
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
