CAD Managers
CelticDesignServices
Message 1 of 5 (802 Views)
w3wp issues and possible fix
802 Views, 4 Replies
04-06-2012 09:51 AM
Just wondering if anyone else has been seeing this issue and how you all addressed it or maybe help you address it.
We've been having Vault Workgroups 2012 come to a stand still a few times, most recently this week.
On top of us finding numerous issues with our older AutoCAD files interacting with Vault (see my other thread here), we have verified that if our w3wp process gets to +1.7gig or more, Vault comes to a crawl or crashes.
What we've been able to verfiy also is that when a user activates a Inventor file out of Vault, this process increases in memory usage and then drops back down to normal once the process is done. But when an AutoCAD file is checked out or into Vault, the memory jumps up as expected, but then it only resets about 1/2. In other words if the Acad file bumps the process memory up by 500mb, when it's done, it only releases 250mb, whereas Inventor releases all 500mb. So what happens is with numerous users all activating Acad files, the memory amount keeps mounting (5 steps forward, 3 steps back) until it eventually reaches the 1.7g range and Vault starts to drag.
The IT department here will now be running or invoking a IIS reset over night each night to clear the w3wp process memory in hopes we don't see this again.
Just wondering how anyone else who might be experiencing this is handling it?
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
TravisNave
Message 2 of 5 (791 Views)
Re: w3wp issues and possible fix
04-09-2012 08:26 AM in reply to: CelticDesignServices
Definitely sounds like a memory leak.  Are you running SP1 and post SP1 hotfix?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9261341#section30
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Message 3 of 5 (777 Views)
04-10-2012 03:27 PM in reply to: TravisNave
We're on SP1, but haven't installed the post SP1 hotfix as of yet.
Jim
Rob.O
Message 4 of 5 (764 Views)
04-11-2012 03:42 PM in reply to: CelticDesignServices
I am not sure that I can offer any help, just a confirmation that we have this issue as well! :smileyhappy:
We see this happen quite often. Our Vault never seems to slow, but frequently locks up.  The strange thing is that it will occur every day for a week (sometimes two or three times a day) and then it will not happen again for 2 weeks, 3 weeks, etc..
We store AutoCAD .DWG files as well as .PDFs, .DOCs, etc... in out Vault (basic), but no inventor files.  Unlike yours, ours will usually get to ~3GB before it locks up.  The ADMS console runs on a dedicated server, so when this occurs, we do a reset of IIS and everything goes back to normal within a few seconds.
We have another server in a remote office that runs Vault Server as well.  I set it up about 6 months ago and have never had to restart IIS.  Granted it is not used nearly as much as the Vault server at this location, but still strange. The local ADMS console is using SQL Express while the remote ADMS console uses the full version of SQL (not sure if that would really make a difference).
I have not install SP1 as of yet.
Hope it helps!
Message 5 of 5 (756 Views)
04-12-2012 11:27 AM in reply to: Rob.O
DB,
I'd suggest doing as our IT guy here did and write up a script to do a daily restart/reset of the IIS process, thus clearing the memory. It's been working fine for us since...knock on wood.
Jim
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
