There are two HELP files most likely: one for plain AutoCAD and one for your
SD feature. Both should list the commandline commands, if they still exist,
that you can type, and therefore can use, in Lisp routines and macros.
These may have changed in 2010, it happens, best way to find out is to start
typing. CUI command will get you into the menus you have loaded for you to
see their codes. Hope that helps.
Dean Saadallah
http://LTisACAD.blogspot.com
