Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
use of LISP in ASD 2010
6 REPLIES 6
BertStragier4945
444 Views, 6 Replies
I made some own tools with AutoLISP for Structural Detailing 2009 but the problem in version 2010 is that the commands on the command line are not available anymore... so the tools don't work now.
Is there anyone who knows how to make some own macros to design reinforcement within Structural Detailling?
6 REPLIES 6
in reply to: BertStragier4945
Sounds like you need to take the time and upgrade your lisps for use with
R2010: do you actually own a copy of R2010? Help there is a good place to
start, as is typing at the command line to see how things work.
Dean Saadallah
http://LTisACAD.blogspot.com
I'm using a Autocad + Structural Detailing 2010 and Help isn't very up to date I think.
Typing on the command line tells me there is one command to start the different menus to draw reinforcement... in ASD 2009 you could enter Diameter, Cover,... on the command line, in 2010 you can't do that anymore.
Is there a way to know how those menus work? I suppose there are commands for the different options (not on the command line) in those menus?
There are two HELP files most likely: one for plain AutoCAD and one for your
SD feature. Both should list the commandline commands, if they still exist,
that you can type, and therefore can use, in Lisp routines and macros.
These may have changed in 2010, it happens, best way to find out is to start
typing. CUI command will get you into the menus you have loaded for you to
see their codes. Hope that helps.
Dean Saadallah
> {quote:title=BertStragier4945 wrote:}{quote}
Why not?
For example:
if you use the command rbcr_def_bar_bv (draw reinforcement - elevation), this opens the menu with the different options (diameter/shape/...).
In 2009 you see the menu but you can also use command line options Diameter/Cover/...
In 2010 you can't anymore, it's just : on the command line.
Forgive me, but I think you are not quite understanding the responses you
are getting.
2010ASD for you has changed: there is no going back to 2009ASD commands in
2010ASD. You will need to rewrite your customizations or drop back to
2009ASD.
The Lisp customization discussion area, if you cannot figure out on your own
how to rewrite them or if you just need to abandon them, is at:
http://discussion.autodesk.com/forums/forum.jspa?forumID=130
Dean Saadallah
Administrator Productivity
