CAD Managers
*MKHenson
Message 1 of 9 (236 Views)
thoughts about color coding
236 Views, 8 Replies
11-06-2000 07:04 PM
I have been struggling with some cad operators about organizing our color
layer scheme. By that I mean using all 20's for a certain color, all 30's
for another color and so on. The problem is that we have so many drawings
already using colors that are fully recognizable on the screen. We have been
programmed to see what a dwg will look like by looking at the screen. My
question is this. Do most of you use an order like I just mentioned or just
use certain colors that are appealing to you? I'm leaning toward using the
colors we are already using and just adapt these as our "standard". My fear
is that it will be more difficult for a consultant or a new employee to
learn. Any thoughts?
Mike
*FH
Message 2 of 9 (236 Views)
Re: thoughts about color coding
11-07-2000 05:57 AM in reply to: *MKHenson
My 2 cents...
We use colors 1 through 12 as basic line weights. Colors 110 is a 10%
screen, 120 is 20% and so forth. It's simple but effective in our case
(small architectural firm). I like using the first 10 because they really
stand apart from each other. We send/request line weight tables from our
consultants so they/we can recreate a plot if needed. We're a small firm so
these quidelines may or may not work for larger, multi-disiplined, companys.
Forrest
"MKHenson" wrote in message
news:F8F59AFF8BE8D81FF9E9B5AB948C88C5@in.WebX.SaUCah8kaAW...
been
just
fear
> Mike
*Follmer, CJ
Message 3 of 9 (236 Views)
Re:
11-07-2000 09:19 AM in reply to: *MKHenson
We have a similar scheme, colors 1 to 15 and the same shading scheme although I've had to go back and add some shade
colors, 250-255 for a government client who of course uses the AIA layers. We're floating with two layer/color schemes,
one for us and one for them. Rather that make two copies for some of our blocks that use shading I just set them for the
250's color and both layering schemes can use. It was lots of fun programming all that so autocad will use one or the
other.
Another scheme that I've heard of is the brighter the color the heavier the line. So white and yellow are heavy, blue is
light etc.
Generally we just go with what colors we like best.
CJ Follmer
For free lisp routines check out my website
For ADT: SaveAsR14, CJsLeader 2.1, CJsKeynotes 2
For 2000: CJsLeader 2.1, CJsKeynotes 2
http://home.att.net/~cjenn
"FH" wrote in message news:014B552DFFE03BB47A39C120C1103F55@in.WebX.SaUCah8kaAW...
> My 2 cents...
> Forrest
> been
> just
> fear
> > Mike
*Zimmerman, Chris P.
Message 4 of 9 (236 Views)
11-12-2000 06:05 AM in reply to: *MKHenson
We are an architectural firm and have to work with many different
consultants and in a crunch have to be able to plot thier drawings. Color to
line weight becomes a real issue.
In an effort to keep uniformity we have adopted the National CAD Standards
and therefore adopted the plotting standards as well. This sets color to
line weight and is a National Standard. It is not perfect and I would
normally change things, however, it is a standard I can dictate to other
consulting firms.
I would suggest that you look into this standard for compatibility. It
seems that the National Standard is growing in acceptance.
Chris P. Zimmerman, AIA
Architect
been
just
fear
> Mike
*Mathews, Plessey
Message 5 of 9 (236 Views)
11-16-2000 03:12 AM in reply to: *MKHenson
Hi all,
Any of you know of freeware layer, linetype and color converter
from one office standard to another.
Thank you
*martin, jason
Message 6 of 9 (236 Views)
Re:
11-16-2000 05:48 AM in reply to: *MKHenson
There is a layer translator in the bonu....I mean express tools that can be used for this.
You have to set up a master translation "matrix" to get from one to the other. The setup
of the "matrix" is somewhat cumbersome but once setup it's pretty easy to convert
drawings.
hth
jason martin
frankfurt-short-bruza
Plessey Mathews wrote in message
news:3a13c0d3.2153291@discussion.autodesk.com...
> Hi all,
> Thank you
*Price, Gordon
Message 7 of 9 (236 Views)
11-16-2000 10:04 PM in reply to: *MKHenson
been
just
fear
I use the setup below. As a color get's more saturated (52 to 62 to 72,
etc.), it plots thicker. Existing is the X1 (i.e. 51, 61,...) series, kind
of washed out, and plots with a screen. New work and demo is the X2 series,
sharper color and plots black. All annotation is an orange color, from pale
(thin, like dimension extension lines) to dark (thick). Walls (and headers
& sills) get their own series to pop them out. Everthing else is set up to
either Squiggle (the hand plot look), for straight items like stairs,
soffits, doors, etc; or to not Squiggle, for curved or short line segment
elements, like furniture and plumbing. Gradients plot as indicated, and
allow for all sorts of nice presentation stuff (like topo as gradients with
a stark white background to the black line plan, (weakly) ala Tadao Ando, or
elevations with poched windows). Once you get used to it, you can read not
only what the line weight will be, but what the architectural content will
be. I think this is the best of both worlds.
As to other people learning it, just document well, give them a reasonable
amount of time to learn it, and let them know that continued employment
depends on doing so :smileywink:
Just my $0.02 worth.
Gordon
Color
Size/Screen
Annotation
30
medium/100%
31
thin/100%
32
thick/100%
Un-Squiggled
51
xthin/70%
52
xthin/100%
61
thin/70%
62
thin/100%
71
medium/70%
72
medium/100%
81
thick/70%
82
thick/100%
Squiggled
131
thin/70%
132
thin/100%
141
medium/70%
142
medium/100%
151
thick/70%
152
thick/100%
Walls
201
thin/70%
202
thin/100%
211
medium/70%
212
medium/100%
221
thick/70%
222
thick/100%
231
xthick/70%
232
xthick/100%
Gradients
250
medium/25%
251
medium/40%
252
medium/55%
253
medium/70%
254
medium/85%
255
medium/100%
*Price, Gordon
Message 8 of 9 (236 Views)
Re:
11-17-2000 11:40 AM in reply to: *MKHenson
 Let's try this again. I pasted the table into
Outlook Express, and it looked fine, but the post it's self looks like hell, so
here it is again in HTML. Crossed fingers.
style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN-LEFT: 0.05in; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-table-layout-alt: fixed; mso-border-alt: solid windowtext .5pt; mso-padding-alt: 0in .05in 0in .05in"
cellSpacing=0 cellPadding=0 border=1>
style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 0.05in; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 0.05in; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 92.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 0.5pt solid"
vAlign=top width=123>
Color
style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 0.05in; BORDER-TOP: windowtext 0.5pt solid; PADDING-LEFT: 0.05in; PADDING-BOTTOM: 0in; BORDER-LEFT: medium none; WIDTH: 96.25pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 0.5pt solid; mso-border-left-alt: solid windowtext .5pt"
vAlign=top width=128>
style="mso-bidi-font-weight: normal">Size/Screen
style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 0.05in; BORDER-TOP: medium none; PADDING-LEFT: 0.05in; PADDING-BOTTOM: 0in; BORDER-LEFT: windowtext 0.5pt solid; WIDTH: 92.6pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 0.5pt solid; mso-border-top-alt: solid windowtext .5pt"
style="mso-bidi-font-weight: normal">Annotation
style="BORDER-RIGHT: windowtext 0.5pt solid; PADDING-RIGHT: 0.05in; BORDER-TOP: medium none; PADDING-LEFT: 0.05in; PADDING-BOTTOM: 0in; BORDER-LEFT: medium none; WIDTH: 96.25pt; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 0.5pt solid; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt"
30
medium/100%
31
thin/100%
32
thick/100%
style="mso-bidi-font-weight: normal">Un-Squiggled
51
xthin/70%
52
xthin/100%
61
thin/70%
62
thin/100%
71
medium/70%
72
medium/100%
81
thick/70%
82
thick/100%
style="mso-bidi-font-weight: normal">Squiggled
131
thin/70%
132
thin/100%
141
medium/70%
142
medium/100%
151
thick/70%
152
thick/100%
style="mso-bidi-font-weight: normal">Walls
201
thin/70%
202
thin/100%
211
medium/70%
212
medium/100%
221
thick/70%
222
thick/100%
231
xthick/70%
232
xthick/100%
style="mso-bidi-font-weight: normal">Gradients
250
medium/25%
251
medium/40%
252
medium/55%
253
medium/70%
254
medium/85%
255
class=table>medium/100%
*H, Scott
Message 9 of 9 (236 Views)
Re:
12-05-2000 09:17 PM in reply to: *MKHenson
what's the story on your 'squiggled' assignment??
"Gordon Price" wrote in message
news:C5B469B0AE3351C1BC5C907BA189FBFF@in.WebX.SaUCah8kaAW...
Let's try this again. I pasted the table into Outlook Express, and it
looked fine, but the post it's self looks like hell, so here it is again in
Color Size/Screen
Annotation
30medium/100%
31thin/100%
32thick/100%
Un-Squiggled
51xthin/70%
52xthin/100%
61thin/70%
62thin/100%
71medium/70%
72medium/100%
81thick/70%
82thick/100%
Squiggled
131thin/70%
132thin/100%
141medium/70%
142medium/100%
151thick/70%
152thick/100%
Walls
201thin/70%
202thin/100%
211medium/70%
212medium/100%
221thick/70%
222thick/100%
231xthick/70%
232xthick/100%
Gradients
250medium/25%
251medium/40%
252medium/55%
253medium/70%
254medium/85%
255medium/100%
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
