is that something custom you've made? I can't find anything like that in
google for more recent than 2002... or perhaps my searching skills are just
woefully inadequate...
http://www.intelcad.com/pages/xrepath/
"Mark McDonough" wrote in message
news:4857475@discussion.autodesk.com...
We use a utility called XRP (Xref Relative Paths). I'm not sure about
AutoCAD 2005/2006, but with 2004 that we use, one can only apply a relative
path when first attaching the XREF. If the XREF already have full paths
incuding drive letter, AutoCAD has no automatic way to convert the full path
to a relative one. Also, the Image command does not have a provision for
relative paths.
So, we still use this XRP utility (works for IMAGE paths too), and our users
can just run XRP after attaching XREFs or IMAGEs, to quickly convert them to
use relative paths. Then one can copy/move a CAD folder tree to any drive
or other folder location, and all XREFs are found.
Mark McDonough
Sasaki Associates
http://www.sasaki.com
wrote in message news:4856991@discussion.autodesk.com...
Our It use the high letters for common drives- W=work, U=user drive etc so
we may have to work in the middle somewhere.
of course that is always assuming we will be able to use removable drives,
all A drives are locked out unless you get a form signed and have a very
good reason for needing one, smae with CD drives etc.
