• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Member
    Accepted Solution
    selection/deselection using shift
    964 Views, 4 Replies
    10-08-2012 02:50 PM
    Does anyone know how to get the selection/deselection using shift to function properly when there are images xref'd to a drawing? I know if you have raster design there is a menu (ioptions) where you can turn off the option that 'shift + select' automatically selects the image rather than deselecting, but ioptions doesnt seem to work if you dont have raster design and I cant find an options dialog that allows me to turn this off otherwise!
    Please use plain text.
    *Expert Elite*
    pendean
    Re: selection/deselection using shift
    10-09-2012 05:37 AM in reply to: jshelton
    Do you just need to turn on the image(s) frame on first? You can't touch them without it on. Otherwise, elaborate in more detail please.
    PICKADD is the variable you seek in your title, seems to work just fine here.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Member
    10-09-2012 07:14 AM in reply to: pendean
    Whether the image frame is on or off 'shift+select' picks it and adds it to my selection. I want to turn that feature off. PICKADD doesn't alter this. I want to be able to select and then remove certain objects from said selection by pressing shift. Or, use shift to swap between trim and extend without having to pick a different command. The image options prevents this.
    I have attached an image of the raster options which shows where you can turn this off if you have raster. However my system doesn't have raster and I cant find where to turn it off otherwise.
    Member
    10-09-2012 07:32 AM in reply to: jshelton
    MAPIOPTIONS  is apparently the command I was looking for. It pulls up the options menu in normal cad where I can turn off the image select feature.
    *Expert Elite*
    pendean
    10-09-2012 02:48 PM in reply to: jshelton
    You must not be using plain AutoCAD then... .
