CAD Managers
Active Member
Message 1 of 9 (498 Views)
" C U I " Searching for complete instructions on customizing 2010 CUI !
498 Views, 8 Replies
07-30-2009 08:09 AM
Hi All,
I am an old MNU / MNS buff and had that method down pat. Recently, I have decided to embrace the new CUI method to customize Acad for my group. The Acad Help file is useful, however it does not seem to tie all the info together into a solid reference. Little and/or important details seem hard to find or are missing, such as the complete relationship between CUI and WorkSpaces.
Does anyone have a clue where I might locate a good and complete reference for working in the 2010 CUI ?
Feel free to flood me with good info.
Thanks folks,
Dave
*Anthony Mason
Message 2 of 9 (498 Views)
Re: " C U I " Searching for complete instructions on customizing 2010 CUI !
07-30-2009 09:42 AM in reply to: shawcorp
If you don't mind being flooded with info, the best place is probably to
search "cui" in this forum. The hardest part will be forgetting
everything you know about MNU/MNS.
As for the Workspace - it lives in the CUI, and controls the visibility
and placement of elements defined in the CUI.
david.cox@shawinc.com wrote:
> Hi All,
> Thanks folks,
> Dave
*Dean Saadallah
Message 3 of 9 (498 Views)
07-30-2009 10:18 AM in reply to: shawcorp
An "oldie but a goodie" is enough to get you started:
http://autodesk.blogs.com/between_the_lines/2005/05/autocad_2006_tu.html
Dean Saadallah
http://LTisACAD.blogspot.com
Active Member
Message 4 of 9 (498 Views)
07-30-2009 11:04 AM in reply to: shawcorp
Thanks, Anthony!
Active Member
Message 5 of 9 (498 Views)
07-30-2009 11:05 AM in reply to: shawcorp
Thanks, Dean. I will check out the info!
GrantsPirate
Message 6 of 9 (498 Views)
07-30-2009 11:24 AM in reply to: shawcorp
http://www.upfrontezine.com/
Tailoring AutoCAD 2010 CUI is a comprehensive tutorial on customizing AutoCAD 2010's CUI -- the Customize User Interface dialog box. 168 pages. US$25.20 PDF
*Jester
Message 7 of 9 (498 Views)
08-04-2009 12:27 AM in reply to: shawcorp
Make a mns and import it.... :smileyhappy:
wrote in message
news:6228062@discussion.autodesk.com...
Hi All,
WorkSpaces.
Thanks folks,
Dave
Distinguished Contributor
Message 8 of 9 (498 Views)
11-11-2009 06:03 PM in reply to: shawcorp
Hi everyone,
I've just had a similar experience as our entire office has moved from using pre CUI versions of AutoCAD to the latest versions and having to implement our tried and trusted extensively customised .mnu files to operate under the CUI. However I used the migration tool which imported all my existing settings as well as converting the .mnu to a .cuix. Put simply, I copied my existing .mnu as well as a renamed .dll file containing the menu icons to the new AutoCAD support directory, i then added the .mnu as a partial menu, which recompiled it into a cuix, adding the old icons contained in the .dll file. I am now very happy with the result: 99% of the old (ACLT2002) menu which we are familiar with works just as it did before. Just be careful and save your workspace when you are happy with menu placement and toolbar locations, prefereably by typing workspace on the command line. I also had trouble with pulldown menu's disappearing when there was two lines of them with duplicate pulldowns from the additional menu loaded, I removed the redundant ones (file, view, etc) from the old menu in the WORKSPACE section of the CUI, and now everything works fine. If you have any more questions, please feel feel to ask them here and i'll try and elaborate some more.
GrantsPirate
Message 9 of 9 (498 Views)
11-12-2009 06:53 PM in reply to: shawcorp
http://www.upfrontezine.com/eBooks/#acad
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
