A while back,
I started a lengthy discussion about the merits of STB,
trying to identify advantages over a CTB standard.
What resulted was there isn't really any advantage to using STB;
other than greater flexibility in output to Color.
And with the advent of True Color,
that reasoning could be called into question.
One thing that did not really come up in discussion,
is how an STB system frees up the User to strategize
on-screen colors to better make sense of the design.
To illustrate this,
I've attached a few images.
I typically color my 'Existing to Remain' Phase elements in a monochrome
white (if your modelspace background is set to black...) utilizing
colors 7,8,9 almost exclusively.
For 'Existing to be Removed' Phase elements; I color them Red - always
monochrome red. (For some reason the color red says 'demo' to me?...)
That leaves the reaming color palette for 'New Construction' Phase elements.
(Unless you'd like to color-isolate 'Future Construction', 'Work by Others',
etc. Phases...)
The resultant model-workspace, is an intuitive color-coded display that
visually categorizes elements by Phase - something I find very nice. This
credo applies equally well to most of the typical drawings one would create
in a Document set: Plans, Elevations, Sections, Details, etc.
Taking this a step further, I also try to cater the brightness of a color
assigned to and element, to it's lineweight. So an existing to remain
element that is color 7, will output heavier than one that is color 9, which
outputs heavier that color 8.
And another step further still, I try and select monochromatic color ranges
for elements based upon the Specification section they are part of. Examples
include 05 Steel items I typically assign a 'blue' color, 07 Thermal and
moisture protections elements, I make a mono-chromatic shade of green, 09
finishes: magenta, and so on...
What happens, is one starts to identify color with phase, and function. And
also makes staring at the screen all day, a little easier one the eyes, IMO.
On the Pspace side, setting the background to white, turning 'Display Plot
Styles' on for the page setup, and activating 'Display Lineweights' (LWT);
you get a nice plot preview-ish kindof workspace; where all of the
modelspace color coding gets converted to a real-world output display.
Granted, this could all be achieved in a CTB environment; and truthfully, I
started organizing my colors this way back when I used CTB. But in using
STB, I enjoy the flexibility in the ability to output any Layer and/or
Element to any plotstyle, at anytime - without the scripted file-creation
requirements of CTB, or having to temporarily set the elements to a Ture
Color.
So, I suppose that I really didn't add anything to the CTB vs. STB argument
after all. Aside from, with STB, if my co-worker finds my on-screen color
scheme absolutely repulsive; he/she can change all of those colors and still
output (to B&W and/or Grayscale...) the same. And that's kindof nice...
