Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
how many cadd techs per engineers
63 REPLIES 63
Message 1 of 64
521 Views, 63 Replies
what the ratio of cadd tech to engineers in your office,
cadd time = 20% of the total project therefor one cadd tech for 4
engineers.
what is everyone else doing??
63 REPLIES 63
Message 41 of 64
Bottomline, it boils down to a balance of people's time and skills, it will
be different for every office. There are engineers in our office that
should not even have AutoCAD installed on their PC, but they do for viewing
purposes.
There are those that could draft circles around the drafters and instead of
taking 3-4 hours to put a red pen to paper, they could probably draft up the
design themselves in about 1-2 hours.
If anyone looks at project costing for a job, you will find more money made
with an engineer that can draft their own work at an efficient pace. Just
do the math:
1-2 hours @ $85/hr. = $170.
3-4 hours @ $85/hr. + 2-3 hours drafting @ $35/hr. = $275.
But this is only holds water depending on project and the talent of the
people involved.
However, another valid point is made that if the engineering and drafting
are affectively segregated from each other, then an engineer can begin work
on the next project while a drafter pumps the redlines. Therefore
increasing the flow of work through the office. It's all a matter of volume
and limiting the number of bottlenecks.
Every office and process is unique. It's easy to say that the most cost
effective employee would be an engineer that happened to have outstanding
drafting skills, making drafters obsolete. But those people aren't too
common, particularly when CAD isn't a required course cirriculum and it's
based on the job experience.
Message 42 of 64
I guess I wonder why any company would hire an engineer that isn't
proficient in CAD and it's engineering programs. Unless, they were a hired
as a Senior Project Manager. These companies that have so many drafters
obviously do not use programs like LDD, if they did 80% of the drafting is
done for you, the rest is just adjusting text so it's ledgible. You can not
give that work to a drafter because you have to be an engineer in order to
do your design with the software.
Message 43 of 64
proficient in CAD
because they are older, with years of experience?... i dunno...
>f they did 80% of the drafting is done for you
randot alert?
>you have to be an engineer in order to do your design with the software.
so only truck drivers can drive trucks?...
attitudes are contagious... mine could kill you...... 🙂
Message 44 of 64
I don't think an engineer should be required to be proficient in CAD - yet.
If that were the case, then it'd be part of course cirriculum at colleges
and universities. It hasn't gotten to that point - yet.
An engineer does what an engineer does, crunch the numbers to make sure the
building will stand up, the bridge won't fall, the power gets where it needs
to go, etc.
A drafter puts those thoughts and ideas onto paper, somewhere along the
line, a good drafter can become worth their weight in gold as they begin to
pickup on the design standards of an office. They begin to see patterns and
know certain things need to be shown a certain way. So no matter how sloppy
redlines may be, you'll get a well done drawing back.
You either need to be open minded enough to view it from another angle, or
have been in a different environment to appreciate it from the 'other'
perspective.
Even with something like LDD, an engineer is a fool to believe that the
software makes his design sound. A good engineer should double and triple
check the stuff, whether he drafts it himself or not. He's setting himself
up for a hurting allowing for a false sense of 'security' thinking that a
design is done better or faster just because he drafted it himself. I've
learned this lesson a couple times myself.
"Jay B." wrote in message
news:C319D6E6852F32FA0488C5FC35CB4954@in.WebX.maYIadrTaRb...
not
Message 45 of 64
Some people in here aren't very pollite. You took everything out of
context, why even bother to reply? Of course only truck drivers can drive
trucks. DUH!
Message 46 of 64
The problem with engineers doing their own drafting is that if you accept
the premiss that it is 80% design and 20% drafting, while they are
designing, they are not drafting so there is no progress on the drawings.
If you can afford to wait until all the design is done befor doing the
drafting, then more power to you.
Plumbing and HVAC don't work that way. There is plenty of "Non-Engineering"
type drafting to do on a project that can be done while the "system design"
progresses. The other thing is that AutoCAD on its own, doesn't support
designing mechanical systems very efficently. It is much easier and faster
to layout systems schematically from hard copy then spend time zooming and
panning around the drawing in AutoCAD.
Dave Alexander
"Jason Wilder" wrote in message
news:B470D618955D249C3BF97E5935722E08@in.WebX.maYIadrTaRb...
yet.
the
needs
> to go, etc.
to
and
sloppy
> perspective.
himself
hired
is
> not
to
Message 47 of 64
I agree. I didn't mean to infer that the design be done before drafting
starts, but a good drafter could put a great deal of the 'non-engineering'
elements on a drawing while an engineer crunches the important info.
The manner in which we 'try' to get work to flow in our office is such that
an engineer runs some calculations, specs equipment, etc. Around the time
he's done, a drafter should have a project setup and drafted with basic
items that the engineer can review and redline a drawing, then hand it back
to the drafter and it gets one last review before going out the door.
Doesn't always flow quite this way, but it's the 'ideal'.
"Dave Alexander" wrote in message
news:0860DC864BD4FB74524C8EF270B6BF3F@in.WebX.maYIadrTaRb...
"Non-Engineering"
design"
> Dave Alexander
Message 48 of 64
That's pretty much the way we work as well. With more experienced "drafters
(techs)" the engineer need only layout the system in a more general nature
and leave the "nitty gritty" to the be done by the drafter.
Dave Alexander
news:86C826E32325B17CE95581AFB96272C6@in.WebX.maYIadrTaRb...
that
back
Message 49 of 64
you said:
"You can not give that work to a drafter because you have to be an engineer
in order to do your design with the software."
i'm not an engineer, but i do civil design... not to the extent of
engineers, but the "easy" stuff they dont/shouldn't spend time on i do....
no kidding... 😐
Message 50 of 64
Randy?
Message 51 of 64
>>I guess I wonder why any company would hire an engineer that isn't proficient in CAD and it's engineering programs. <<
It's about billing rates. A good designer (billed at $45-$65) can do much (if not all) of the preliminary design work. That'll leave an engineer (billed at $60-$80) with review and approval. It's cheaper to the client. You'll have 3-4 designers (at a lower rate) working for 1-2 Enginees (at the higher rate).
Message 52 of 64
>>That's pretty much the way we work as well. With more experienced "drafters (techs)" the engineer need only layout the system in a more general nature and leave the "nitty gritty" to the be done by the drafter.<<
Much of the time in our shop, the designers have enough experience in the disicpline to it all, and leave only review and approval to the engineer.
Message 53 of 64
thats how it works in my shop...we a new designer
starts he must have another desinger review his work first..before it goes to
the engineer
Jaime
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
drafter.<<
engineer.
Message 54 of 64
Wow, the subject changed in this thread!!
Engineers defending their jobs and tech's defending theirs.
I think a better definition of a "cadd tech" is lost here. A person
that does straight cadd work (ie, move text around, create titlesheets,
inserting std. details into a dwg are considered "cadd drafters" NOT cadd
technicians. If your proficient in your field and progressed to doing
designs, then "cadd tech" would be the term. (The Cadd Techs) are MOST
valuable to any firm!.
I was under the impression that someone can NOT be labeled "Engineer"
unless they had their registration. Our company (ENR500 firm) changed
titles for all employees. If you have a 4yr degree with or without EIT then
you are a Project Designer or Project Manager. If you have your PE, you can
be called an engineer. (you guessed it, EIT's and others are EQUAL)
Some States, like Texas, made it a State Law that its prohibited to call
one-self an engineer without a license.
This thread at ASCE is a good subject on the issue
http://www.asce.org/forum/messageview.cfm?catid=21&threadid=149
Most cadd tech's make more (or should) cash than an entry level engineer
with zero experience. I bet 90% of cadd techs could run circles around any
new grad. Myself, I have my degree, and EIT, but enjoy the work. Before
degree, it started with Leroy, Mylar, Stickybacks, Acad12/DCA, nightschool.
Not interested at all in Management, so I don't persu my PE. Who knows,
someday before I retire I might. Once you go management, you loose touch
with software and designing. Staying on top of the latest and greatest in
Autocad will be lost. (not that it has progressed since LDD2 anyway, but
thats our problem being consumers to the giant).
Anyway, this is my current thought on this subject, who knows. Its probably
the Atkins diet killing my braincells. gosh I want pasta!!
"KARL DETRICK" wrote in message
news:1C85D6CF32744E12ACDDC88D461469D9@in.WebX.maYIadrTaRb...
> engineers.
Message 55 of 64
I think the size of the company and the size of the project
has a lot to do with who does what. As well as the basic
setup of responsibilities within the company. On company I
worked for had engineers engineer, designers design,
drafters draft and so fourth. Eventually the designers were
doing the drafting by the nature of CAD. Now in all
fairness this was a very large company with a staff of 7000+
world wide working on large projects.
The responsibilities of the engineers didn't leave them much
time for CAD. The actual involvement varied from discipline
to discipline. The next company I was at was much smaller.
Some of the engineers used Cad to do sketchers, but when it
came to the day to day production of hundreds of drawings,
they couldn't come close to the "CAD GUYS" I guess this all
comes down to, practices vary widely based on size of
company, size of job being done, and company practices.
My 0.50 cents worth.
Pete
Message 56 of 64
Karl hit the nail right on the head. EIT's as well as Engineering
Technicians
are most valuable. Sure we don't put together proposals to actually drum up
the work. But alot of engineers don't have the CADD management skills to
care how
to put together a plan set. I work in an office where we do mostly
DOT work and believe me when I say that the engineers don't have the time
or desire to know how to draft. All of the drafting is left to the EIT's and
the
CADD "Technicans" to do. We currently have 5 Engineers, out of which only
3 do actual design, 4 EIT's, 4 drafters, 1 bridge tech, and 2 Engineering
Technicans.
As for the CADD Drafters, they will always have a job. How many engineers
really
get a thrill out of doing their own tabulations and quantity sheets? or
drawing details?
It's like saying drafters never should have never been a position, what is
the difference
between doing layout on paper or in CADD? It's just gotten faster is all,
but what has
also gained momentum is the rate at which we can scrap a whole idea and
start out new.
As for billing rates I am a Senior CADD Designer with 9 years experience and
I bill
out at over $70.00 an hour, EIT's at $60.00 and hour and the engineers
billed out at
$70.00 to $120.00 an hour. With my overtime rate I make alot more than most
of the
ten year engineers out there. The attitude with this post was the same as
the first position
I held. " Your a CADD guy you draw pretty lines and circles. The EIT's get
to do the
design." What a crock, these EIT's not only don't have a clue how to design
out of
college, they also could'nt draw the pretty lines or circles. I doubt this
firm ever learned
their mistakes, but it was much to their loss, as I subsequently took a
design position
elsewhere.
"WU" wrote in message
news:E901AFB3B50DF46592731B20C0465D38@in.WebX.maYIadrTaRb...
then
can
any
nightschool.
probably
> > engineers.
Message 57 of 64
Right on Kevin, but you never should have let it out of the
bag that we designers often make more than the engineers.
"Kevin" wrote in message
news:4A503E3DB4A404F8FA685243C095A89B@in.WebX.maYIadrTaRb...
Engineering
> Technicians
actually drum up
> care how
do mostly
don't have the time
> the
out of which only
and 2 Engineering
> Technicans.
many engineers
> really
quantity sheets? or
> drawing details?
position, what is
> the difference
faster is all,
> but what has
whole idea and
> start out new.
> I bill
the engineers
> billed out at
alot more than most
> of the
was the same as
> the first position
> to do the
clue how to design
> out of
> firm ever learned
subsequently took a
> design position
> elsewhere.
theirs.
here. A person
create titlesheets,
drafters" NOT cadd
progressed to doing
Techs) are MOST
labeled "Engineer"
firm) changed
or without EIT
> then
have your PE, you
> can
others are EQUAL)
prohibited to call
circles around
> any
the work. Before
Acad12/DCA,
> nightschool.
PE. Who knows,
LDD2 anyway, but
knows. Its
> probably
pasta!!
office,
tech for 4
> > > engineers.
Message 58 of 64
So, would you prefer paying $70-$120 an hour for filling out terminal schedules or $40 for a CAD drafter?
Message 59 of 64
If the $70 an hour person can do it in one hour and
the $40 an hour person can do it in TWO hours the $70 an hour person just saved
you ten bucks.
So,
Message 60 of 64
Unless, of course the $40 /hour person does it in
1/2 hour.
Administrator Productivity
