Let's see if I can clearly explain the system that we use. We are
manufacturers of safety equipment.
When the saleman recieves the order for preliminary drawings, the job
is given a six digit number that stays with the job throughout the
entire process(i.e. 101657). While this drawing is in the preliminary
stage is is Q-101657-1. Q for quote and -1 for page number.
Once the job is bid and accepted, the approval stage begins. A job
folder is then created on the server and the approval drawings
101657A01 for approval page one, 101657A02 page two and so on. If
revisions are made, 101657A01R1.
Once the customer give approval for manufacture, the drawings become
details for the manufacture of the product, 101657D01,etc.
The drawings that accompany the equipment are assemblies and these
drawings are numbered 101657E01.
This system makes for easy file retrival from archives. All you need
is the job number and explorer does the rest. Happy Holidays.
On Thu, 21 Dec 2000 06:42:02 -0800, rossiarc@pacbell.net wrote:
>We are having some difficulty in setting up a file management system.
>Right now we use a job number for each job, a code for the file type, a
>code for the revision number, and a code for the contents. For example:
>"R00100a_pA1.dwg" designates job number 001, revision a, page A1 in the
>drawing set. We use a different file name for every file so in the event
>of a mix up of files I can find the proper location for the file. Where
>our problem lies is that when a new revision is created, all files are
>copied to a new folder and renamed. Then all xreferences have to be
>updated in all files because the file name changes. On small jobs that
>is not a problem but for large projects, this take take a lot of time.
>Does anyone have any suggestions or know of any resources as to how we
>can retain different file names for all files, maintain separation and
>ease of use, wile also not having to go through the whole updating all
>xreferences task?
