CAD Managers
New Member
marcosbav
Message 1 of 2 (428 Views)
block editor crash
428 Views, 1 Replies
06-12-2012 01:32 PM
Hi
I went into the Block editor to changea block I use fairly often.when i closed the editor, everything was gone. When I've tried opening the "crashed" dwg I get a dialog box that says: .dwg "contains authoring elements. Open in block editor?" Then in the editor for the block name it says <current drawing>, if I close the editor and save the change I have a drawing with one block. If I don't save the change coming out of the editor, it closes the drawing.
using the recover tool, it repair over 4000 errors, but at the and I only have the same drawning with only one block.
Have y'all ever seen anything like this before?
Charles_Shade
Message 2 of 2 (412 Views)
Re: block editor crash
06-14-2012 12:04 PM in reply to: marcosbav
Yes and there is a fix for that. Search for your Version here:
Block Editor Save Corruption Hotfix
I know that AutoCAD and LT have had this problem.
Some more from the KB:
http://usa.autodesk.com/adsk/servlet/u/bsearch/results?qt=Block+Editor+Crash&siteID=123112&catID=182...
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
