>are you as confused as I am?
>(this is completely hard to explain,
>if you're not Matt S.)
You're in luck! I _am_ Matt S., so I may be of assistance
I'll first explain that yes, your original idea about plot-only "sheet" drawings
referencing the design files as xrefs is perfectly valid - we've been using the
technique for some time. I think by now it's pretty much industry standard
practice.
However, relative pathing, in your configuration, has some problems in the
manner you've described. This is because you are both referencing from the same
directory (design xrefs into design xrefs) and across nested folder boundaries
(design xrefs into CD sheet files). Specifically, your problem with referential
pathing is that the sheet files cannot find the nested design Xref file(s) -
simply because the relative pathing cannot take folder nesting into account.
In other words, let's say in the \Project\Drawings\xref\ folder, you have PLAN
and RCP. RCP references PLAN. Without full hard coded paths, the Xref path is
simply "PLAN.DWG". With relative pathing, it is ".\PLAN.DWG" because it's in the
same folder as the parent file. It could also be referenced as
"..\Xrefs\PLAN.DWG" - the "..\" evaluates to the parent folder of the "." which
is the current folder.
However, this saved path falls apart when you reference RCP into the Sheet file
(e.g., A1-2.DWG) that is one folder above, in \Project\Drawings\, because while
the RCP path is relative at "xref\RCP.DWG" it cannot find ".\PLAN.DWG" because
it's not in the same folder as the A1-2.DWG file. Using the double-dot method
does not work either, because the saved path is "..\Xrefs\PLAN" which doesn't
exist at the \Drawings level.
Solutions?
(1) put everything in one folder. I found this to be unacceptable for most
projects of any size.
(2) Use hard coded paths, always. Problematic because of inflexibility with
moving folders around, but it IS bulletproof. Especially if you have a
standardized file naming system that reuses the same file names across projects.
(3) Break out your folders into a parallel structure so that relative pathing is
one level deeper from the same root, using "..\" to reference the root folder
one step above.
To wit:
Use \Project\Drawings\Xrefs for Design files
Use \Project\Drawings\CDs for Sheet files
Under the Working files, relative path from \Drawings, not from .\ (the current
directory) via "..\"
E.g.,
\Project\Drawings\Xrefs\RCP.DWG references "..\Xrefs\PLAN.DWG" - the two dots
evaluate to "\Project\Drawings\". Now you have the base from which all future
pathing can relate to this parent folder, instead of the current folder and
folders below.
So now, when you reference RCP into "\Project\Drawings\CDs\A1-2.dwg", the file
references "..\Xrefs\RCP.DWG" which ALSO references "..\Xrefs\PLAN.DWG" and it
all comes together. Xrefs is under the Root (\Drawings) as is CDs.
This only works when we're using a parallel structure for both CDs and Xrefs,
pathing off the root of \Drawings\. If you don't use parallel folders, and
instead use a nested structure (e.g., \Drawings\ for CDs and \Drawings\Xrefs for
design) the system falls apart because at the \Drawings\ level, children design
files (RCP.DWG) would be referencing "..\Xrefs\PLAN.DWG", which won't resolve
because the path that would _work_ would be "..\Drawings\Xrefs\PLAN.DWG".
So, maintaining a parallel structure works with relative pathing, and has a few
advantages besides:
1) You can have subfolders under CDs and Xrefs which pertain to those types of
files only. For example, I always maintain a \Bakups folder in each for BAK
files, which gets them out of the main folder and reduces clutter. Under CDs you
could have \Plots, and under Xrefs you could have \Trash. It keeps the folder
structure neater and doesn't interfere with cross-referencing files.
2) You can move the whole \Drawings root, and all references below this work as
well, if they are relative pathed in this manner.
Problems with relative pathing:
We use standard file names for design (xref) files to reduce the learning curve
going from project to project. It also makes file management easier at the
server level. However, with relative pathing, you will find yourself in a
situation where references will pull in the wrong drawing from a different
project. This happens when you switch projects without quitting AutoCAD, because
AutoCAD's working directory is the same one used when you launch the app by
dbl-clicking on a drawing icon.
So, for example, if you open up \CDs\A1-2.dwg in ONE project, it may actually
pull in ..\Drawings\Xrefs\PLAN.DWG from a completely different project folder,
because the root "\ProjectA\Drawings" will be referenced, not
"\ProjectB\Drawings\". Which is why I abandonded relative pathing and stuck
w/hard coded xrefs. I like standard names, and I can repath a whole lot of Xrefs
in no time.
Matt
mstachoni@comcast.net
mstachoni@beyerdesign.com
Matt
On Fri, 12 Jul 2002 14:15:25 -0700, "Corey A. Layton"
wrote:
>ok, here's the scoop...
>I had this relavation:
>I was setting up my directory structure to be used for CAD dwgs.
>And I thought to myself
>"Always make the xref (design, Work, etc. whatever you call it) directory
>a sub directory of the plotted dwgs. So that relative pathing could be used,
>and the nested xrefs will always resolve, wherever the project directory
>"tree" is moved to (another drive, archived to cd, another parent directory,
>etc.)"
>so I set it up like this:
>(there are WAY more subdirectories under the project folder, but this
>illustrates my point)
>\\Drawings
>this is where the plotted dwgs go that xref design files
>These dwgs are opened to plot only, no CAD data here other than xrefs
>relative path: Work\.dwg
>\\Drawings\Work
>this is where the design dwgs go that xref consultant files
>These dwgs are opened to edit CAD data,
>may xref consultant CAD data
>relative path: xref\.dwg
>\\Drawings\Work\xref\
>this is where the consultant CAD files go (read only)
>These dwgs are for coordination, no editing here.
>It all sounded so nice.
>But my system was flawed:
>I made the assumption that an "attached" (vs. "overlayed") xref (A.dwg)
>that resolves with a relative path, will also resolve when it's parent
>drawing (B.dwg) is xreffed into another dwg. (C.dwg).
>not so.
>A.dwg lists as "unresolved" in C.dwg
>because A.dwg's relative path saved in B.dwg
>won't resolve from C.dwg.
>if A is attached to B and B to C,
>shouldn't A resolve in C?
