• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    *PF
    Re:
    04-24-2003 03:10 PM in reply to: *Laurich, Jeff
    My problem with the Parents is they Raised them with that attitude - and
    probably had innumerable chances to rectify it!
    > "cad user" wrote in message
    > news:BEFAB3618806FAE4546A4C6A6637319F@in.WebX.maYIadrTaRb...
    > > I did not slander you so what's your problem? If they are cheating they
    > > don't care about the class. You should spend your efforts on the ones
    > that
    > > are very interested and having trouble. You are giving attention to the
    > > wrong students. Advise their parents and let them take care of it.
    Please use plain text.
    *PF
    Re:
    04-24-2003 03:22 PM in reply to: *Laurich, Jeff
    Jason -
    Time, it seems, has taught you (at least) that learning is full of bruises-
    and your story sounds wholly inequitable- but I'd point out that a teacher
    must do all possible to expose work that is not original ... to the best
    of their abilities.
    Could you offer us a way: How would you have caught the person who stole
    your work? If only your instructor had a better way...
    Jason Hickey wrote in message
    news:B68C9DA44DE8CAF0DC67C7560B613342@in.WebX.maYIadrTaRb...
    > Jeff,
    > I've been in your described situation, only from the student's point.
    > Here's my story:
    > He said that I had cheated, he was very upset, and that the only way I
    could
    > make up for it was to have a hand drawing of the assembly in his hands by
    > noon the next day. He said that three of us had cheated, and not to try
    to
    > go to the dean about it, because he would have us expelled. I was upset,
    > needless to say, but knew that I had to do what he wanted to keep from
    > getting an "F" in the class. I stayed up, literally, all night working
    on
    > it, missed work the next day, and finally finished. .... When I got to
    > his office, he took it and apologized to me. Seems like this guy in the
    > class (a real slacker) had seen me working on mine and copied my floppy
    when
    > I wasn't looking (we were back and forth to the plotter). He re-named
    the
    > files, plotted them out, and turned them in as his own work. He finally
    > confessed when put under pressure. I was told that the assembly drawing
    > would count for extra credit, but it ended up not counting for anything (I
    > really wanted that one back, I was VERY proud of it.). I was not a happy
    > camper for days, but finally put it behind me.
    > I guess what I'm saying is, please make sure that the person you accuse is
    > really guilty. That's been well over 10 years ago, and I'm still not
    quite
    > over it.
    > Jason Hickey
    > Goodwyn, Mills, and Cawood, Inc.
    > 1102 South 20th Street
    > Birmingham, Alabama, 35205
    > (205) 879-4462
    > www.gmcnetwork.com
    > (Take me out to reply)
    > "The Ozone layer or cheese in a spray can....don't make me choose."
    *Marchetto, Eugene
    Re: Your Cheatin Heart
    04-24-2003 08:29 PM in reply to: *Laurich, Jeff
    Jeff,
    For future classes, you can easly program a template file that has VBA code
    embedded into it. The code can easily attatch xdata to each entitiy that is
    created and modified automatically. The xdata can contain information about
    the login name of the user, machine name and time & date for each event of
    each entity. By having the program embedded in your supplied template, you
    would not have to have a distributed file that would cause suspision.
    I think the suggestion of Entity handle names will work if the exact drawing
    was copied and used from the start. If entities were wblocked or copied and
    pasted out, the handles would change.
    Good Luck!
    Dreamcad
    Gene Marchetto
    973-728-3928
    dreamcad@optonline.net
    "Jeff Laurich" wrote in message
    news:2BC678FD7E5B14FBAFB8222EFCA2706F@in.WebX.maYIadrTaRb...
    > To All:
    > I am an instructor at a Technical College teaching beginning level AutoCAD
    > and I have recently discovered that 2 of my students are "sharing" their
    > assigned work. In other words, they are turning in the same drawings as
    > their own.
    > I am 99% sure that they are cheating but need to be 100%. When I use the
    > TIME command in AutoCAD, it tells me that both drawings were created at
    the
    > exact same 1/100 of a second. That's pretty solid evidence, I think,
    except
    > for the fact that they could have started with the same template or
    drawing
    > file. I also checked a few random objects in the drawings and the handles
    > are identical. That seems to be the deciding clue for me that they are
    > indeed using the same drawing.
    > Does anybody else have any other ideas on how I can be sure about this?
    Are
    > handles as random as I think they are?
    > Thanks for your time,
    > Jeff
    *S, Tim
    Re:
    04-24-2003 10:22 PM in reply to: *Laurich, Jeff
    Craig, also be careful not to get the idea that all of your students come
    from one typical mold. You will run into students who are strangely
    intelligent and will come up with very ingenius ways to get a job done. You
    must take the time to physically look at what the student has done, even if
    this means sitting down with every student, and saying, "Ok, explain how you
    approached this." This is where the learning takes place, not at the monkey
    see monkey do level. There is never a definite "have to" in doing cad work
    and some people, especially kids can come up with some really cool ideas on
    how to approach something. If you want to know if they cheated ask a few
    questions, the truth will come out. One simple question like "What layer did
    you use for the camshaft?" Can tell you a lot about whether they are the
    actual creator or not.
    Tim
    "Craig Black" wrote in message
    news:F849E923FD5646E32D69B495966C5F46@in.WebX.maYIadrTaRb...
    > Marshall,
    > I work with Jeff - and that's the first thing that we do; check the number
    > of entities in the drawing. If its not the same as our "check" drawing,
    5%
    > off right off the bat... (these are not terribly extravagant drawings)...
    > Craig Black
    > ATC Manager
    > Fox Valley Technical College
    > "Marshall Caudle" wrote in message
    > news:B8DCF67E81E51602192CD8CF89151312@in.WebX.maYIadrTaRb...
    > > If it's a Technical College where they paid money to attend - then they
    > are
    > > cheating no one but themselves.
    > > Years ago I audited an AutoCAD class and found it interesting that the
    > > instructor graded a CAD file not on the drawing but how much memory it
    > took
    > > to do the drawing. At the time I actually had a later version of
    AutoCAD
    > > than the school and better equipment at home, but I did learn the value
    of
    > > "memory efficiency" in producing CAD drawings and even today my CAD
    > drawing
    > > files are a lot smaller than many others doing the same type of
    drawings.
    *Hickey, Jason
    Re:
    04-24-2003 11:37 PM in reply to: *Laurich, Jeff
    To be truthful, I don't have a better way to catch the person that cheated.
    My main point is that he a) jumped to conclusions quickly, before he had all
    the facts and b) was extremely nasty about it. As we all know in the
    professional world, there's a professional way and an unprofessional way to
    voice displeasure. His way was akin to a kindergarten tantrum.
    Jason Hickey
    (205) 879-4462
    www.gmcnetwork.com
    *P., Danny
    Re:
    04-24-2003 11:50 PM in reply to: *Laurich, Jeff
    Jeff/Allen,
    You've hit the nail on the head here. The two students, and let's assume
    they're working independently, would have had to mirror EVERY command
    exactly as the other had done, to the letter in order for the handles to be
    the same. If one of them added one single entity that the other didn't,
    whether a point, a line, a layer, anything, then every handle from that
    point on would be different for the two drawings. If you observe that the
    handles of the last object added were the same, then there is no way
    (reasonably) they they are unique drawings. You can type this in on the
    command line to check "(entget (entlast))" to return the handles of the last
    entity. If they're the same, you've got cheaters.
    -Danny Polkinhorn
    Perkins & Will
    Atlanta
    "Allen Jessup" wrote in message
    news:76566E2E5F190AC6DDF06DE3972A1ADF@in.WebX.maYIadrTaRb...
    > I think you have enough info from other answers to determine the DWG's are
    > identical. Just to answer one part of your question. Handles are not
    random.
    > They are hexadecimal numbers assigned in ascending order. If your two
    > drawing were supposedly developed independently and not started from a
    > common template. The chances of to objects having identical properties,
    > including the handles, are extremely remote. Even if they inserted the
    same
    > standard blocks they shouldn't have the same handles. Handles are so
    > sacrosanct that even in the days when there was a "Destroy Handles"
    command
    > you had to enter strange confirmations like "UNHANDLE THAT DATABASE" to
    get
    > the program to complete the command. Now there is no longer even that
    > option.
    > Just couldn't resist the little history lesson.
    > Allen
    > > To All:
    AutoCAD
    > > their own.
    the
    > the
    > except
    > drawing
    handles
    > Are
    > > Jeff
    *PF
    Re:
    04-25-2003 03:10 AM in reply to: *Laurich, Jeff
    I agree- and my initial response is to line them up against the wall with
    blndfolds and.... (G)
    This does require a bit of creativity and thought!
    news:122FA1676092B893C7409259F5BEDA3A@in.WebX.maYIadrTaRb...
    cheated.
    all
    to
    > Jason Hickey
    > (205) 879-4462
    > www.gmcnetwork.com
    *S, Tim
    Re:
    You could also get in front of the class and say "What we have here, is a
    failure to communicate." Then put the one you think is guilty into a small
    box out in the hot sun. It straightened Paul Newman's smart alecky butt
    right out!
    Tim
    "PF" wrote in message
    news:4AC66E1A2C2C253F1E6F790BEFC58FB3@in.WebX.maYIadrTaRb...
    > cheated.
    > all
    > to
    > > Jason Hickey
    > > (205) 879-4462
    > > www.gmcnetwork.com
    *Black, Craig
    Re:
    04-27-2003 08:07 AM in reply to: *Laurich, Jeff
    Thanks, everyone for your concerns in the fairness of my grading methods.
    (and I am not being facetious, I mean it!)
    I have been doing this for about 13 years now, so I am quite satisfied with
    my methods and the results they produce. The class is very entry level and
    I only do this "entity count" deal on the final exam. The students are told
    to reproduce a simple "gasket" type drawing - and they are told to reproduce
    it EXACTLY as shown. When I am checking the drawings, I issue the SELECT
    command and merely window the drawing area and examine the entity count. If
    its off, I start looking for overlapping entities and two part lines... that
    sort of thing. I don not take 5% off for a bad count - and not tell them
    where they went wrong - that wouldn't be right. The students are told
    during the course that it is very important when working out in industry
    that they should be able to know what to expect when they have to modify
    someone else's drawing or if someone else has to edit theirs - that person
    should know what to expect. So they are very forewarned as to what I am
    looking for... But thanks for keeping an eye on me and making sure I am
    doing things right! :smileywink:
    Craig
    "Tim S" wrote in message
    news:084C424552F58B8E38E3EC426E7C5C99@in.WebX.maYIadrTaRb...
    You
    if
    you
    monkey
    on
    did
    > Tim
    > > Marshall,
    number
    > 5%
    drawings)...
    > > Craig Black
    > > ATC Manager
    they
    > > are
    > > took
    > AutoCAD
    value
    > of
    > > drawing
    > drawings.
    *jemery0630
    Re:
    04-27-2003 09:01 PM in reply to: *Laurich, Jeff
    Not critizing your grading policy. Your the teacher. I am just saying that
    there are more than one way to draw a square (4 lines, 1 polyline or 1
    rectangle, to name a few). I am just asking how you maintain an enviornment
    which tries to yield the correct # of entities, so that there is a fair
    grading foundation. Do you tell your students not to use plines or
    rectangles and to just use lines? I'm asking just ro gain knowledge from
    someone with a little bit more teaching experience. To tell the students to
    just use lines would limit there use of the software and furthermore limit
    there knowledge of it as well. Please take these comments half-heartedly.
    I'm only looking to better my teaching skills. Thanks
    news:smileyvery-happy:E65149537D997B351AAC1C774C20C2E@in.WebX.maYIadrTaRb...
    with
    and
    told
    reproduce
    If
    that
    > Craig
    come
    > You
    > if
    > you
    > monkey
    work
    > on
    > did
    > > Tim
    > > > Marshall,
    > number
    drawing,
    > > 5%
    > drawings)...
    > > > Craig Black
    > > > ATC Manager
    > they
    > > > are
    the
    it
    > > > took
    > > AutoCAD
    > value
    > > of
    > > > drawing
    > > drawings.
