I shut off a layer or layers and/or isolate layers, and then UNDO, but the prior layer state is not brought back. Now what has happened with AUTOCAD?--which seems to to have a mind of its own? (Autocad 2009). I never paid much attention before, but haven't had this problem until recently as far as I can tell.
Example from command line:
Layer "RFRG06" has been turned off.
Select an object on the layer to be turned off or [Settings/Undo]:
Command: u LAYOFF GROUP
It says it undid LAYOFF, but it doesn't do that as the layer is still off! Regenall does nothing either. so it's not a visibility or regen issue
PS--I verified that this is just happening in a particular drawing. How frustrating is that? I did an audit and it said there were no issues. (Yeah, right.)
Also, I am curious about what I have popping up as "bastard layers". Layer (names) which seem to create themselves with a $ sign as part of the name?
Edited by: ckrtom2%20 on Jun 9, 2009 4:57 PM
