Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
What do you think about Trusted DWG?
151 REPLIES 151
Message 1 of 152
jorgeledezma
3042 Views, 151 Replies
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6740482
151 REPLIES 151
Message 21 of 152
rculp
in reply to: jorgeledezma
"" I use and will continue to use DWGgateway without so much as ONE problem. And I have converted literally 100's of files. ""
As long as you're translating from one AutoCAD version to another there shouldn't be much trouble, but going from MSTA to AutoCAD is not as seamless as the Bentley boys would have you think. We had a vendor taken off our suppliers list because he was continually sending in crud translated from MS to AutoCAD that were nothing BUT trouble.
But hey, that's just me.
Randall Culp
Civil-Structural Design Technician
(aka CADaver)
Message 22 of 152
madcadd
>>Then just name them, or better yet name just one "" FREEBEE* program[] that work as well and *BETTER* than AutoCAD. ""
Reply From: Don Reichle
Date: Jun/09/06 - 15:46 (CDT)
Re: What do you think about Trusted DWG?
Well I was just talking about this with other staff in the office a few
minutes ago, and our common experience was to use IntelliCAD to clean up DWG
files that had become corrupted beyond Audit/Restore process while having
been retained inside AutoCAD previously.
So that fairly well flies in the face of the post we were lead to from that
link, hmmmm?
Message 23 of 152
I find the same thing here. We run both ACAD and MS and I use MS to open
and fix files that ACAD Audit/Restore can't fix. The file was in only used
in ACAD until then so what is so trusty about that?
Speaking of MS, if you really know how to use and configure MicroStation you
really don't have any problems. The only time I see issues with it is when
users who think they know what they are doing and say they understand MS and
then have issues with it. I set it up and use it and it works fine so is it
the software or user error?
"Don Reichle" wrote in message
news:5201893@discussion.autodesk.com...
link, hmmmm?
The procedure I referred to above was c-o-n-s-i-d-e-r-a-b-l-y faster than
having to start all over from an empty dwg file, I'm sure even the Deskers
would agree.
And that would need to include the "checking" involved to make sure that all
the necessary changes had been addressed.
Which made me think of any Agency changes required - based upon the
timeframe of this unfortunate happenstance of corruption.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT/CD-2K4
AMD Athlon 64 X2 Dual 2.01GHz
XPPro 32bit SP2
2GB RAM
Dual WD800JD Hard Drives - 149GB Nvidia Stripe
Nvidia Quadro FX 1300 128MB
Dual ViewSonic 19-inch VA902b monitors
wrote in message news:5201036@discussion.autodesk.com...
Message 24 of 152
On Fri, 9 Jun 2006 17:04:08 +0000, Randy Culp <> wrote:
>"" Unfortunately, we can't get a utility that tells us which files were crappily drawn ""
>Knowing it was done in MSTA is a good start.
Meh - people do good CAD work using MSTA, AutoCAD, and
Barbie's Home Deck Builder. I've gotten MTSA-originated
files that were, for the most part, just fine. The only
weirdness I had was dealing with layers with intuitive names
like, say "17."
But, for most of us in the real world, the software used to
create the DWG file doesn't matter until _after_ the
contracts have been written and signed and design is well
under way.
By then, it's simply too late.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
Message 25 of 152
It may be likely that my friend Allen had issues with DGN files that were
converted to DWGs, after they had already been "graced" with issues from MS?
Not ever having utilized MS, I of course may be all wet with my guess re.
the "causes" of his troubles with the DWG files he mentioned.
Don Reichle
LDT/CD-2K4
XPPro 32bit SP2
2GB RAM
"Michael Kolster" wrote in message
news:5201953@discussion.autodesk.com...
link, hmmmm?
would agree.
Don Reichle
LDT/CD-2K4
XPPro 32bit SP2
2GB RAM
Message 26 of 152
rculp
"" I'm in violation of nothing, I just work here. ""
Then, if all those versions are not separate licenses, your employer is in violation of the EULA. If they'll steal from AutoDESK what makes you sure they won't steal from you?
Randall Culp
(aka CADaver)
Message 27 of 152
rculp
"" I've gotten MTSA-originated files that were, for the most part, just fine. ""
Depends on the file, the user, the version of MSTA, the "Enhanced Precision" settings, the MU-SU-PU setting, and how the originator translated the file into AutoCAD. I've seen perfectly fine looking MSTA drawings turned into mush trying to save them as AutoCAD. Some so bad even MSTA wouldn't open them anymore.
"" But, for most of us in the real world, the software used to
create the DWG file doesn't matter until _after_ the contracts have been written and signed and design is well under way. ""
We contract deliverable formats, so we know what we're getting from the top.
Randall Culp
(aka CADaver)
Message 28 of 152
rculp
"" to clean up DWG files that had become corrupted beyond Audit/Restore process while having been retained inside AutoCAD previously. ""
Since R13, this office (150-300 users) has had maybe 10 files that would not recover.
"" our common experience was to use IntelliCAD to clean up DWG files ""
Intellicad chokes large on the 3D files we generate on a regular basis.
How often do you guys get corrupt drawings?? Have you attempted to determine the cause?? or just assumed it was the program??
Randall Culp
(aka CADaver)
Message 29 of 152
jorgeledezma
Why we haven't a Trusted DOC, XLS...?
If a software detect any corrupted file there are 2 ways: repair and open the file or no open the file at all.
Don't you think that with 2K7 we are in the middle of a big break: dwg and Trusted DWG? To leave the competition behind and make us more ADSK dependable users?
Trusted DWG is a dwg more armored than ever, a bullet proof dwg format.
I am wondering how this trusted platform will help to the multiuser environment or to databases driven applications.
Will see Trusted DWG centric applications?
Message 30 of 152
rculp
"" fix files that ACAD Audit/Restore can't fix. The file was in only used in ACAD until then so what is so trusty about that? ""
Does this happen to you often? What 3rd party apps do you have loaded??
"" Speaking of MS, if you really know how to use and configure MicroStation you really don't have any problems. ""
There again, that depends on the version of MS and certain settings in effect while producing the file in MSTA and the settings used for the translation.
"" is it the software or user error? ""
Oh, without a doubt, it's pilot error. But the fault lies with the Bentley propaganda that claims seamless transition between the two programs. It is only seamless (not really then either) if you do due diligence in setting up the translation. Unfortunately, many users don't, they heard it was easy, so they just save as autocad and send me the fie. They usually get it back that afternoon.
Randall Culp
(aka CADaver)
Message 31 of 152
rculp
"" Trusted DWG is a dwg more armored than ever, a bullet proof dwg format. ""
What are you smokin' dude? Read the link you posted again.
Randall Culp
(aka CADaver)
Message 32 of 152
So do we, but there's nothing stating that specifying files
in "AutoCAD 2000+ DWG format" means they were actually MADE
in AutoCAD.
Specifying file formats for data communication is one thing.
Telling someone what software they _must_ use to create the
file is something completely different,
Matt
Message 33 of 152
rculp
For some of our vendors/suppliers we now specify a full RECOVER log screen capture accompany the files. Sure that can be manipulated, but it's usually easier to just do the job right. We contract full compliance with our standards as well (no layers 1, 2, 3, etc., no bogus scaled elements, no over-ridden dimensions, no dimassoc=0, no self xref's, and on and on). And we provide all the tools necessary to comply with our standards using AutoCAD.
I'm no longer in the business of fixing MSTA translated files.
Randall Culp
(aka CADaver)
Message 34 of 152
Jack,
The warning for drawings with the "PRODUCED BY AN AUTODESK EDUCATIONAL
PRODUCT" educational plot stamp is in AutoCAD 2004 and up.
Tracy Lincoln - Autodesk Discussion Group Facilitator
TLConsulting - http://TLConsulting.blogspot.com/
"JMT-02" wrote in message
news:5201473@discussion.autodesk.com...
I think you get an education stamp warning if you open an education created
dwg when using commercial versions of AutoCAD 2006, and probably the same in
2007.
Not having done so myself, I am can't swear to it, but I remember reading
that it is so, about a year ago or when 2006 came out.
As for the warning messages about a non AutoCAD created DWG file, it is
better than no warning. It gives a possible place to look when corruption
screws up a dwg file.
Jack Talsky
Message 35 of 152
Thanks. I will take being 1/3 right as opposed to never right.
Jack
"Tracy Lincoln" wrote in message
news:5202164@discussion.autodesk.com...
Jack,
Message 36 of 152
madcadd
You are truly ridiculous!
My employer is the State I live in.
Wanna take another guess?
Message 37 of 152
rculp
"" My employer is the State I live in ""
Just cuz' it's a state government does not mean they are above shady dealings. Some state agencies would be the poster children for shady.
Notice I said IF, not are. IF they are all above board, and every installation is in accordance with the EULA, then cool. IF NOT they are thieves, and as such will steal from you just as quick as they will from AutoDESK.
Randall Culp
(aka CADaver)
Message 38 of 152
Must be nice to live on Planet Randy.
Here on Earth, reality is somewhat different in how much we can hold our
consultants' collective feet to the fire.
Matt
Message 39 of 152
jorgeledezma
LOL
Message 40 of 152
rculp
"" in how much we can hold our consultants' collective feet to the fire. ""
Depends on the contract. And where you are on the pecking order. I would suspect, you'd be on the other end of our contracts.
Randall Culp
(aka CADaver)
Administrator Productivity
