• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Distinguished Contributor
    Re: What do you think about Trusted DWG?
    06-09-2006 02:22 PM in reply to: JorgeLedezma
    "" I use and will continue to use DWGgateway without so much as ONE problem. And I have converted literally 100's of files. ""
    As long as you're translating from one AutoCAD version to another there shouldn't be much trouble, but going from MSTA to AutoCAD is not as seamless as the Bentley boys would have you think. We had a vendor taken off our suppliers list because he was continually sending in crud translated from MS to AutoCAD that were nothing BUT trouble.
    Please use plain text.
    06-09-2006 02:28 PM in reply to: JorgeLedezma
    >>Then just name them, or better yet name just one "" FREEBEE* program[] that work as well and *BETTER* than AutoCAD. ""
    Reply From: Don Reichle
    Date: Jun/09/06 - 15:46 (CDT)
    Well I was just talking about this with other staff in the office a few
    minutes ago, and our common experience was to use IntelliCAD to clean up DWG
    files that had become corrupted beyond Audit/Restore process while having
    been retained inside AutoCAD previously.
    So that fairly well flies in the face of the post we were lead to from that
    link, hmmmm?
    *Michael Kolster
    06-09-2006 02:36 PM in reply to: JorgeLedezma
    I find the same thing here. We run both ACAD and MS and I use MS to open
    and fix files that ACAD Audit/Restore can't fix. The file was in only used
    in ACAD until then so what is so trusty about that?
    Speaking of MS, if you really know how to use and configure MicroStation you
    really don't have any problems. The only time I see issues with it is when
    users who think they know what they are doing and say they understand MS and
    then have issues with it. I set it up and use it and it works fine so is it
    the software or user error?
    "Don Reichle" wrote in message
    news:5201893@discussion.autodesk.com...
    link, hmmmm?
    The procedure I referred to above was c-o-n-s-i-d-e-r-a-b-l-y faster than
    having to start all over from an empty dwg file, I'm sure even the Deskers
    would agree.
    And that would need to include the "checking" involved to make sure that all
    the necessary changes had been addressed.
    Which made me think of any Agency changes required - based upon the
    timeframe of this unfortunate happenstance of corruption.
    Don Reichle
    "The only thing worse
    than training your staff,
    and having them leave is -
    not training your staff,
    and having them stay."
    Courtesy Graphics Solution Providers
    LDT/CD-2K4
    AMD Athlon 64 X2 Dual 2.01GHz
    XPPro 32bit SP2
    2GB RAM
    Dual WD800JD Hard Drives - 149GB Nvidia Stripe
    Nvidia Quadro FX 1300 128MB
    Dual ViewSonic 19-inch VA902b monitors
    wrote in message news:5201036@discussion.autodesk.com...
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6740482
    *Matt Stachoni
    06-09-2006 03:18 PM in reply to: JorgeLedezma
    On Fri, 9 Jun 2006 17:04:08 +0000, Randy Culp <> wrote:
    >"" Unfortunately, we can't get a utility that tells us which files were crappily drawn ""
    >Knowing it was done in MSTA is a good start.
    Meh - people do good CAD work using MSTA, AutoCAD, and
    Barbie's Home Deck Builder. I've gotten MTSA-originated
    files that were, for the most part, just fine. The only
    weirdness I had was dealing with layers with intuitive names
    like, say "17."
    But, for most of us in the real world, the software used to
    create the DWG file doesn't matter until _after_ the
    contracts have been written and signed and design is well
    under way.
    By then, it's simply too late.
    Matt
    mstachoni@comcast.net
    mstachoni@bhhtait.com
    *Don Reichle
    06-09-2006 04:40 PM in reply to: JorgeLedezma
    It may be likely that my friend Allen had issues with DGN files that were
    converted to DWGs, after they had already been "graced" with issues from MS?
    Not ever having utilized MS, I of course may be all wet with my guess re.
    the "causes" of his troubles with the DWG files he mentioned.
    Don Reichle
    LDT/CD-2K4
    XPPro 32bit SP2
    2GB RAM
    "Michael Kolster" wrote in message
    news:5201953@discussion.autodesk.com...
    link, hmmmm?
    would agree.
    Don Reichle
    LDT/CD-2K4
    XPPro 32bit SP2
    2GB RAM
    06-09-2006 04:44 PM in reply to: JorgeLedezma
    "" I'm in violation of nothing, I just work here. ""
    Then, if all those versions are not separate licenses, your employer is in violation of the EULA. If they'll steal from AutoDESK what makes you sure they won't steal from you?
    06-09-2006 04:50 PM in reply to: JorgeLedezma
    "" I've gotten MTSA-originated files that were, for the most part, just fine. ""
    Depends on the file, the user, the version of MSTA, the "Enhanced Precision" settings, the MU-SU-PU setting, and how the originator translated the file into AutoCAD. I've seen perfectly fine looking MSTA drawings turned into mush trying to save them as AutoCAD. Some so bad even MSTA wouldn't open them anymore.
    "" But, for most of us in the real world, the software used to
    create the DWG file doesn't matter until _after_ the contracts have been written and signed and design is well under way. ""
    We contract deliverable formats, so we know what we're getting from the top.
    06-09-2006 04:56 PM in reply to: JorgeLedezma
    "" to clean up DWG files that had become corrupted beyond Audit/Restore process while having been retained inside AutoCAD previously. ""
    Since R13, this office (150-300 users) has had maybe 10 files that would not recover.
    "" our common experience was to use IntelliCAD to clean up DWG files ""
    Intellicad chokes large on the 3D files we generate on a regular basis.
    How often do you guys get corrupt drawings?? Have you attempted to determine the cause?? or just assumed it was the program??
    06-09-2006 05:08 PM in reply to: JorgeLedezma
    Why we haven't a Trusted DOC, XLS...?
    If a software detect any corrupted file there are 2 ways: repair and open the file or no open the file at all.
    Don't you think that with 2K7 we are in the middle of a big break: dwg and Trusted DWG? To leave the competition behind and make us more ADSK dependable users?
    Trusted DWG is a dwg more armored than ever, a bullet proof dwg format.
    I am wondering how this trusted platform will help to the multiuser environment or to databases driven applications.
    Will see Trusted DWG centric applications?
    06-09-2006 05:14 PM in reply to: JorgeLedezma
    "" fix files that ACAD Audit/Restore can't fix. The file was in only used in ACAD until then so what is so trusty about that? ""
    Does this happen to you often? What 3rd party apps do you have loaded??
    "" Speaking of MS, if you really know how to use and configure MicroStation you really don't have any problems. ""
    There again, that depends on the version of MS and certain settings in effect while producing the file in MSTA and the settings used for the translation.
    "" is it the software or user error? ""
    Oh, without a doubt, it's pilot error. But the fault lies with the Bentley propaganda that claims seamless transition between the two programs. It is only seamless (not really then either) if you do due diligence in setting up the translation. Unfortunately, many users don't, they heard it was easy, so they just save as autocad and send me the fie. They usually get it back that afternoon.
