• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Distinguished Contributor
    What do you think about Trusted DWG?
    299 Views, 151 Replies
    06-09-2006 04:23 AM
    http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=6740482
    Please use plain text.
    *Allen Jessup
    Re: What do you think about Trusted DWG?
    06-09-2006 05:21 AM in reply to: JorgeLedezma
    Due to recent decisions in creating programs like Civil 3D autodesk would
    have to protect the drawing files. Instead of storing design data in
    external databases like Land Desktop. Civil 3D stores everything in the DWG
    file.That's also why they now include Vault with C3D.
    Now if you're asking if there is a marketing component to this. There
    probably is. It never surprises me when a company engages in marketing.
    My own experiences. Many people mention that MS can save in a DWG format.
    Any time I get one of those I have to Audit it a couple of times before I
    can use it. Otherwise it will create a few interesting errors. I discovered
    this when some drawing kept crashing. I finally found that the cause was
    having unaudited MS generated drawings XRefed into those files.
    Allen
    wrote in message news:5201036@discussion.autodesk.com...
    06-09-2006 06:00 AM in reply to: JorgeLedezma
    Cool. It's about time.
    06-09-2006 07:29 AM in reply to: JorgeLedezma
    Trusted DWG?
    It's a bunch of hooey! They are just running scared from *FREEBEE* programs that work as well and *BETTER* than AutoCAD.
    Remember that Autodesk *USED TO* charge $150.00 for their convertor until competition FORCED them to give it out free!
    I use and will continue to use DWGgateway without so much as ONE problem. And I have converted literally 100's of files.
    Does this sound like I am an AutoCAD basher? It may, but it is the TRUTH as I see it.
    I love AutoCAD. We use SolidWorks here as our primary 3D parametric software, but AutoCAD is still the best 2D software anywhere. We also have IV7 (last one before giving up on it). I doubt that I'd be able to talk the purse strings into another stab at IV. Even though I would like to see IV11.
    *SD'y
    06-09-2006 07:37 AM in reply to: JorgeLedezma
    What to say?
    So, a trusted drawing will never crash?
    Why did it crash? It's a trusted drawing?
    It's not my fault. It is a trusted drawing after all.
    *Matt Stachoni
    06-09-2006 08:17 AM in reply to: JorgeLedezma
    The statement page is FULL of typical corporate gobbledygook, espousing an
    incredible amount of "nothing" for the number of words used.
    The only benefit I can see from this statement was that apparently no trees were
    killed in its publishing.
    For example:
    "At the option of the user, AutoCAD 2007 will notify users when the DWG file
    they are opening was saved using an application that was not created by an
    Autodesk product or RealDWG licensee."
    Okay, swell. But do I really care? Consider the next line:
    "This will help to protect a customer’s DWG data from corruption and give users
    warning that the DWG file they are opening may cause stability issues."
    Woohoo! Protecting our drawings from corruption! Along with a warning that I got
    a POTENTIALLY BAD DRAWING! Sweet!
    But how does this work?
    "...Trusted DWG does not itself repair defects in the file that may exist but
    enables the customer to choose whether or not to accept risks that may be
    associated with DWG files that were not last saved by an Autodesk or RealDWG
    licensee product."
    Oh. ok. um.
    In other words, it amounts to nothing but a warning. Which MAY OR MAY NOT POSE A
    PROBLEM.
    I wonder if you get a warning from a file produced with Educational versions of
    AutoCAD, which can easily and effectively infect your company's drawing files
    with that stupid plot stamp.
    Matt
    mstachoni@comcast.net
    mstachoni@bhhtait.com
    *JMT-02
    06-09-2006 09:13 AM in reply to: JorgeLedezma
    I think you get an education stamp warning if you open an education created
    dwg when using commercial versions of AutoCAD 2006, and probably the same in
    2007.
    Not having done so myself, I am can't swear to it, but I remember reading
    that it is so, about a year ago or when 2006 came out.
    As for the warning messages about a non AutoCAD created DWG file, it is
    better than no warning. It gives a possible place to look when corruption
    screws up a dwg file.
    Jack Talsky
    Valued Contributor
    06-09-2006 09:39 AM in reply to: JorgeLedezma
    Actually I at first hairy eyeballed this concept.
    However, it was pointed out that this also picks up converted files, such as
    those caddus horrabilus files we get from people using MicroStation or
    ArchiCAD.
    As the CAD Manager, I like the idea of knowing where the file we may be
    using as the basis of our documents has come from. Not that I've never had
    AutoCAD corrupt a file, but still a welcome bit of "advice".
    Reid M. Addis
    Registered Architect
    Architectural Applications Manager
    Granary Associates
    411 North 20th Street
    Philadelphia, PA 19130
    Ph. 215-665-7056
    Cell. 215-313-0995
    email: addis@granaryassoc.com
    *Matt Stachoni
    06-09-2006 09:48 AM in reply to: JorgeLedezma
    >ArchiCAD.
    I would LOVE a utility that pointed out errant linework that was put on the
    wrong layer, or lines that are "sort of but not quite parallel" that were used
    to represent walls.
    Unfortunately, we can't get a utility that tells us which files were crappily
    drawn :/
    Matt
    06-09-2006 09:56 AM in reply to: JorgeLedezma
    Opening a Educational drawing will first prompt you with a large alert box asking if you want to continue, made by an educational copy, yada yada, pick ok, another smaller warning comes up adking again if you really want to continue or not.
