Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Volume Shadow Copy Enabled
1 REPLY 1
1219 Views, 1 Reply
Is AutoCAD Volume Shadow Copy Enabled application on Windows? As in does it create consistent copies of the files if the backup is run while AutoCAD has drawings open?
Tags (1)
1 REPLY 1
Bernd.Gerstenberger
Yes, AutoCAD can use the service of volume shadow copy. If a file is open it will be saved as a shadow with the current status quo. BAK-files will be saved, too. Volume Shadow Copy mitigates file access between applications and the backup process. In other words, if a backup tool needs to access a file currently in use, Volume Shadow Copy creates a shadow copy of that file and then provides the backup process access to the shadow copy.
Bernd G.
Senior Product Support Specialist
Administrator Productivity
