Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
Unpurgeable file
11 REPLIES 11
Message 1 of 12
nicolasoterob
1251 Views, 11 Replies
Unpurgeable file
This file was made by copiyng a line form an "infected" one.
After erasing it whats left it´s a bunch of unpurgeable textyles that spread like a virus.
Is there a way to eliminate them?
NOB
11 REPLIES 11
Message 2 of 12
pendean
in reply to: nicolasoterob
Your files contains the following:
DGN Linetypes Purged : 728
DGN Complex Linetypes Purged : 57084
DGN Text Styles Purged : 236
Registry Applications Purged : 7
Annotation Scales Purged : 16
You need 2015 AutoCAD if you just want to PURGE them out, read this for other options if you have lower versions of AutoCAD: http://cadpanacea.com/node/411
Message 3 of 12
nicolasoterob
in reply to: pendean
Thnks man,
I have Autocad 2012, so I'm kind of f..k! LOL
Message 4 of 12
Kyle-Evans
Look in the subscription center for DGN hotfix or something to that effect, I know they released one for Civil 3D 2013, not sure about ACAD though.
Message 5 of 12
abubakars
Try with Free batch tools available to download from Autodesk Exchange App store which has built-in command to purge the DGN-Linetypes from AutoCAD version 2012 to 2015
BatchInEditor -  This would be useful for large amount of files which opens each file in AutoCAD, so user can add their lisp and script routines as well
BatchInDatabase - This would be useful if you want clean large amount of files without opening the files, takes less processing time
LayoutManager - Handy for current drawing opened in AutoCAD which has lots of Layout related commands including command to Purge DGN-linetypes
Message 6 of 12
nicolasoterob
in reply to: abubakars
Thanks guys for your help!
None of the recommended apps worked.
They failed over and over again!
Message 7 of 12
pendean
Really? Done in AutoCAD 12012 with the tools mentioned above.
Message 8 of 12
nicolasoterob
I´m uploading result images from the apps
They all kind of work the same way.
At the end of the process they say something like :Apllication does not support JIT debugging.
Message 9 of 12
abubakars
I tried your file with AutoCAD 2012 and 2014 and both worked here.
Message 10 of 12
abubakars
You may try the alternative method to remove the DGN linetype using BatchInEditor and this would remove the complete dictionary which may result in loosing of some entities which are using the DGN lintype.
1. Add the command "Lisp Expression" and copy and paste the below lisp code
(dictremove (namedobjdict) "ACAD_DGNLINESTYLECOMP")
2. Add Purge-All command
Message 11 of 12
pendean
You have Windows OS security settings issues: JIT is about your system restrictions. Talk to your I.T. Folks Or ask a guru tecchy friend to help you out with that stuff.
Message 12 of 12
nicolasoterob
You where right!
It worked!!!
Security problems.
Thanks for your help!
NOB
Administrator Productivity
