• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Active Member
    davidlewis5275
    Turn off layers in PDF plots via lisp
    323 Views, 2 Replies
    07-24-2012 11:56 AM
    Does anyone know how to turn off including layers in the export to PDF
    I need to roll this setting out to everyone so I need a lisp or registry solution.
    http://www.cadtutor.net/forum/showthread.php?64352-How-to-turn-off-layers-in-your-AutoCAD-PDF-Plots
    Please use plain text.
    Distinguished Contributor
    Re: Turn off layers in PDF plots via lisp
    07-25-2012 02:37 PM in reply to: davidlewis5275
    I have never seen any api for editing pc3 files, which is where the setting is.
    I can edit page setups, but that is as close as I have seen.
    I bet if you find someone that does know of a pc3 editing api, you will be on the right track...
    Active Member
    davidlewis5275
    07-25-2012 02:56 PM in reply to: jmaeding
    Already fixed the PC3 file
    There is sheet set publish options, export to pdf options and users swear they are using Adobe Acrobat.
