style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Bill" <billdog@msn.com> wrote
in message
href="news:C318EC67B01EEAE3E5E0A6E9A5AC254F@in.WebX.maYIadrTaRb">news:C318EC67B01EEAE3E5E0A6E9A5A......
The object properties box is limited. In previous
versions you could do more with text using the cht command. I don't know why
they don't have it anymore but I just use it any way. Fastest way I know how
to change the width of all the text in a dwg globally. Can't do it with
the object properties.
"Miguel" <miguel@zianet.com>
wrote in message
href="news:f140894.10@WebX.maYIadrTaRb">news:f140894.10@WebX.maYIadrTaRb...
the most efficient use of cad is not neccesarily the initial creation of
the work but in the ability to reuse the work. I have noticed 2 camps those
that get it and those that don't. CAD standards free the operator and project
manager from determining conventions and procedures
for each new project.
People who naysay cad standards using the "get it done" mentality are
simply using cad as a fancy pencil..just like using a word processor the same
way as a typewriter.
This fancy pencil method is about the same speed as
hand drafting in my opinion and is some cases slower.
The time gained by
sloppy cad is lost in duplicate because of the problems that can and will
arise.
Garbage in...Garbage out
Miguel
"mary_eatinger" <> wrote in message ...My office (we're
frequently told) has an excellent cad standard system. I believe we're having
a problem with people spending way too much time keeping the system perfect
and spending less time on actual production and quality control of the
projects. I'm as guilty as everyone else. It's easy to find yourself chasing
dimension lines around the page to size all the tick marks perfectly before
you realize it doesn't matter after it's plotted. We've seen sets of drawings
from many other firms that look like they had monkeys for cad operators but I
wonder if they're actually saving time and getting projects out faster with
less stringent cad standards. The idea is to get the project out, permitted
and built? Right?
Has anyone else out there had any experience in how to balance cad
perfection with production? Obviously better project management is the answer,
but we're small and everyone's managing their own projects. Any opinions? How
is everyone else using cad standards, but not to the point that that's all
people focus on?
"Kent Elrod" <
href="mailto:kent.elrod@sumcousa.com">kent.elrod@sumcousa.com> wrote in
message
href="news:86B9CE6E7D60BF4C7ADA07145B756187@in.WebX.maYIadrTaRb">news:86B9CE6E7D60BF4C7ADA07145B7......
Mary
Everyone needs to remember that on most projects
the drawings are not just to get it built. The owner of the building
will be relying on those drawings for 30 or more years to manage the
facility. There are always projects after the fact to modify a process
or change a space. If the drawings are turned over to the owner in bad
shape then future work is going to go to someone else. I am speaking
from an owners point of view because I now work for a manufacturing
firm. There are several companies here in town that will not being doing
work here because of their lack of attention to detail on the designs as well
as the cad monkey syndrome.
I don't prescribe a lot of our own standards
because I know how hard that is to change from job to job, since I have also
been on that side of the fence. But I do require some adherence to the
simplest of standards, and that they stick to their own standards. I had
a drawing submitted to us with column bubbles 2" in diameter. I
complained about the size and they said I hadn't covered it in my standards to
them, which is true, but I would expect anyone to know that column bubbles
printed on a page should be in the 3/4" dia. range. This was just the
tip of the iceberg with them, and needless to say we go else where when we
need things done outside.
So, keep those drawings looking good because it
has an effect on future work.
Kent Elrod
"Kent Elrod" <
message
Mary
Kent Elrod
having a problem with people spending way too much time keeping the system
perfect and spending less time on actual production and quality control of
the projects. I'm as guilty as everyone else. It's easy to find yourself
chasing dimension lines around the page to size all the tick marks perfectly
before you realize it doesn't matter after it's plotted. We've seen sets of
drawings from many other firms that look like they had monkeys for cad
operators but I wonder if they're actually saving time and getting projects
out faster with less stringent cad standards. The idea is to get the project
out, permitted and built? Right?
answer, but we're small and everyone's managing their own projects. Any
opinions? How is everyone else using cad standards, but not to the point
that that's all people focus on?
"Dave Alexander" <
href="mailto:dalexander@pooleandassociates.bc.ca">dalexander@pooleandassociates.bc.ca>
wrote in message
href="news:79B8F4734335B5E4E6AC81EA88D4C556@in.WebX.maYIadrTaRb">news:79B8F4734335B5E4E6AC81EA88D......
Kent,
You are the only one that I have heard say
anything about the owner. Did you know that there is a facilities management
N.G.?
However, the best way to manage other drawings is
with layer management. With Layer Translate, you can change other layer
systems to match your needs and at the same time force intities to all
properties "bylayer". You can also do this without changing any layers.
Dave Alexander
"Kent Elrod" <
in message
href="news:86B9CE6E7D60BF4C7ADA07145B756187@in.WebX.maYIadrTaRb">news:86B9CE6E7D60BF4C7ADA07145......
Mary
projects the drawings are not just to get it built. The owner of the
building will be relying on those drawings for 30 or more years to manage
the facility. There are always projects after the fact to modify a
process or change a space. If the drawings are turned over to the
owner in bad shape then future work is going to go to someone else. I
am speaking from an owners point of view because I now work for a
manufacturing firm. There are several companies here in town that will
not being doing work here because of their lack of attention to detail on
the designs as well as the cad monkey syndrome.
had a drawing submitted to us with column bubbles 2" in diameter. I
to them, which is true, but I would expect anyone to know that column
bubbles printed on a page should be in the 3/4" dia. range. This was
just the tip of the iceberg with them, and needless to say we go else where
when we need things done outside.
Kent
Elrod
