• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    TOP 3 CAD SYSTEMS AVAILABLE
    718 Views, 8 Replies
    03-07-2012 08:52 PM
    Hello to everyone
    I am a CAD student. I am doing research into different CAD systems available.
    Could you please tell me what is the top 3 CAD systems available in the market today?
    I would like to ask out of these three CAD systems which is best & why?
    Please could you give me a brief actual reason to why it is better than the other two, instead of just an opinionated reason, if that's not too much to ask of anyone who reads this.
    Thank you very much
    for taking the time out and
    responding to this discussion topic.
    Kindest regards
    A CAD Student.
    Please use plain text.
    skintsubby
    Re: TOP 3 CAD SYSTEMS AVAILABLE
    03-07-2012 11:50 PM in reply to: 20112679
    You may need to be a bit more specific as it all depends on what you want to do.
    Schematics may only need AutoCAD LT
    Some mechanical work may require Solidworks / Inventor
    Shipbuilding may use Tribon / Fortran
    Process may use PDMS  / AutoCAD / Inventor  / Solidworks ...etc
    The list is endless.
    And as most of the users on here are using AutoCAD then chances are the majority may have that in the top three as that's what they use.
    That said. There's a wealth of knowledge on these board... if you ask the correct question.
    CAD Systems Can we say WHY this one?
    03-08-2012 06:23 AM in reply to: skintsubby
    Hello
    I would like to post this question for discussion.
    What are the main advantages and disadvantages
    Inventor 2012 has over any other CAD packages out there?
    Why is Inventor better than say Solidworks 2012 and say the
    latest version of Mechanical Desktop.
    Why should anyone wishing to invest in a 3D modelling system
    pick Inventor.
    I am doing research into this matter. I could do with some factual help.
    Does anyone know any advantages or disadvantages any of these 3 systems have over each other?
    Not just opinions. Although any help would be very much appreciated.
    Kindest regards
    A CAD Student.
    dgorsman
    Re: CAD Systems Can we say WHY this one?
    03-08-2012 10:10 AM in reply to: 20112679
    Lots of marketing documents out there which detail what each program does.  If you put the hype to one side, you can get most of the information you are looking for.  If you want a starting point, look at the forums with the most posts - these are typically the most common products.
    Adopt. Adapt. Overcome. Or be overcome.
    Valued Mentor
    CelticDesignServices
    04-02-2012 07:57 AM in reply to: 20112679
    Speaking from someone who went thru the comparision of Solidworks vs Inventor a few releases back to decide which one my employer was going to make as the program of choice, we had a 3rd party firm compare both per our requirments and needs. For us, it was hands down Inventor.
    Acouple of the main reasons, data exchange...we had and dealt with numerous other cad programs (SW, Catia, Pro/E, etc.), Inventor was the ONLY one that was able to deal with these files cleanly. By 'cleanly", I mean they inported/exported without issues.
    Our parts were very tight tolerance parts, typically held to the 3rd & 4th decimal for proper fit-up. When going thru the import/export routines, it was found that 6 of 10 (60%) of the files imported/exported in SW were off as of the 3rd decimal by an average of .003". Granted, this may seem like no big deal to most, but for our product it was a killer (think a piston moving up and down in a cylinder with no oil lubricant at high speed...thats what we had to deal with). Whereas the Inventor files were correct out to the 9th decimal.
    Again, chances are, you or most others will not need this amount of accuracy, but it was what made our decision for us.
    Just so you know, we conducted this test 3 seperate times ourselves to verify results in addition to the 3rd party's tests and found the same results. The 3rd party you ask? The late, great Dennis Jeffrey.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
    Charles_Shade
    04-04-2012 01:01 PM in reply to: 20112679
    Never been off the LT farm so I do not know what I'm missing but for residential design I've never
    thought that I needed more.
    Would I have been somewhere else if I had been introduced to Chief Architect? The world may never know.
    Regards, Charles Shade            Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
      Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    04-11-2012 12:19 PM in reply to: 20112679
    A CAD Student.
    Uhmm, if you are still around - Mechanical Desktop has not been sold as a product by Autodesk since Feb of 2002 and was completely discontinued in 2009.  Everyone made the transition to Inventor long ago.
    Inventor Professional 2014 Edu 64-bit
    04-24-2012 09:46 AM in reply to: 20112679
    The fact that Autodesk has a large "family" of applications such as Navisworks, Inventor, Revit, AutoCAD and "flavors" of AutoCAD such as Electrical, Civil, P&ID, etc. may give it an advantage over other applications. Solidworks, for example is a good product, probably as good as Inventor, but has a relatively narrow focus.
    Distinguished Contributor
    ACADuser
    07-12-2012 08:08 AM in reply to: dgorsman
    "...look at the forums with the most posts - these are typically the most common products."
    Or possibly the most complicated product to use.
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
