I'd make sure you can produce your product before jumping.
I've seen several placed work out how they will model things, but not how they will use the model to label.
Will the C3D styles even do what you need?
If not, custom macros needed...
So you might be able to model faster in C3D, just be sure you don't have to dump alignments back to LDT for labeling,
thus introducing a non-linked situation between the callouts and the model.
I can say that for my users, its about 1 hour between when they ask how to make an alignment, and when they ask how they
can use it to label in their plan sheets/exhibits. You have to have that answer ready. Sky's the limit after that.
lsimms <>
|>Hi,
|>We have not so recently brought Civil 3d into the office. I have been spending time going through it, learning, creating styles, etc. So far I have surfaces set up, alignments, profiles, and assemblies. I have even started our first real project on it. Also I have created a step by step manual for everyone.
|>My question is how far I should take things before getting everyone else started on it. We want to get into parcels and pipes. We didn't use them at all in Land, but figure it is time to start. I have not even looked at those sections of the program yet. What is currently set up takes us further and faster than what we were doing in Land. Boss is starting to push. I am starting to agree to the idea of getting everyone started now with what we have, and then once they are comfortable, then start introducing new things like pipes and parcels. Is this a reasonable idea or am I letting myself get brainwashed?
|>How have others made the switch?
|>(small office, 10 ppl will be using it)
|>Thanks
James Maeding
Civil Engineer and Programmer
jmaeding - at - hunsaker - dotcom
