melsen813 <> wrote in news:5614380@discussion.autodesk.com:
> I recently transferred to Boise, ID. I'm trying to do CAD work over
> the network from the company server located in Seattle, WA. Accessing
> AutoCAD files over the network has been extremely slow, sometimes 30
> minutes to open a file. Although I'm copying the files locally, the
> xref path is still pointing to the corporate server. Once I get the
> file open I then re-specify the xref paths to the local server in
> Boise. It has not been a very efficient process. Does anyone have any
> software suggestions, or tips to speed the process up?
When I need to do this I use a terminal connection (or remote desktop
connection if you don't have a terminal server) on a Windows 2003 Server
(if you have one), so the only thing downloading is the display,
everything else functions as if you are logged on to your network. This
isn't perfect, and at times it does get slow and frustrating, but it is
far superior to trying to download and upload every file you work on,
especially if they are large files.
I have tried using Remote Desktop to log directly into the computer I
use in the office, and it does work, but for some reason it does not
work nearly as well as connecting to the server.
