• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Charles_Shade
    Stair Detailing
    423 Views, 2 Replies
    01-15-2013 12:40 PM
    I've been approached about doing stair drawings for metal fabricators.
    What, if anything, are you all using software wise and what should I look for?
    And any thoughts you may have. Thanks.
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Please use plain text.
    PaulMunford
    Re: Stair Detailing
    01-19-2013 01:03 PM in reply to: Charles_Shade
    As always, it depends on the results required.
    If they want a 'specification' model/drawing to give to Architects I would recommend Revit.
    If they have their process down and they just want some simple calculations, AutoCAD will do it.
    If they want folded metal details, frame cut lists, hole patterns etc, I would recommend Inventor.
    There are more specialized programmes out there. I know that Radan (makers of AlphaCAM) do some specific CNC code generating programmes for Timber stairs - I'm not sure about metal ones, sorry!
    The CAD Setter Out Blog
    @CadSetterOut
    Please use the Mark Solutions! Accept as Solution or Give Kudos! Kudos functions - Thank you!
    Charles_Shade
    Re: Stair Detailing
    01-21-2013 03:27 PM in reply to: PaulMunford
    Thanks for the input.
    Most of this is the other way around: Architect specifies the shaft and other info and the fabricator needs shop drawings.
    A fabricator in my area suggested products from SSDCP. Apprently these are discipline specific and have shapes, connections, templates already to go.
