CAD Managers
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Shrinkwrap for AutoCAD: LISP
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
1436 Views, 5 Replies
02-11-2011 06:41 AM
Anyone have a LISP routine that will create a border around selected objects?
Lke shrinkwrap?
Thanks.
_______________________________________________________________
ITO - Application Management
Factory Design Suite Ultimate 2012
AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
Re: Shrinkwrap for AutoCAD: LISP
Options
- Highlight
- Email to a Friend
02-11-2011 01:06 PM in reply to:
jclaidler
You might also ask that question in the LISP forum. You might get better results.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP
Good Luck!
Travis Nave
My Expert Contributions to the Discussion Groups:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Shrinkwrap for AutoCAD: LISP
Options
- Highlight
- Email to a Friend
02-11-2011 03:37 PM in reply to:
jclaidler
Simply draw a loose rectangle around your objects and use the BOUNDARY command, then erase the outer rectangles.
Options
- Highlight
- Email to a Friend
02-14-2011 10:48 AM in reply to:
jclaidler
Nope, not like WIPEOUT. Easily stated, I need a line drawn around the outside edges of selected blocks.
Options
- Highlight
- Email to a Friend
08-16-2012 10:39 AM in reply to:
jclaidler
Easy. Draw a closed polyline (rough) rectangle just outside your block or any object you want. Then use the BOUNDARY command with lsland detention. Choose Region or Polyline as Object type to create. Pick OK, then Enter if you do not want to select addition interal boundaries. Erase the orginal rough rectangle and outer boudary on it. You're left with your object plus the inner boundary shrinkwrap. No Lisp needed. Done!
