CAD Managers
Valued Mentor
jclaidler
Message 1 of 7 (2,908 Views)
Shrinkwrap for AutoCAD: LISP
2908 Views, 6 Replies
02-11-2011 06:41 AM
Anyone have a LISP routine that will create a border around selected objects?
Lke shrinkwrap?
Thanks.
_______________________________________________________________
ITO - Application Management
AutoCAD 2014 | Inventor Professional 2014 | Vault Professional 2014
TravisNave
Message 2 of 7 (2,889 Views)
Re: Shrinkwrap for AutoCAD: LISP
02-11-2011 01:06 PM in reply to: jclaidler
You might also ask that question in the LISP forum.  You might get better results.
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/bd-p/130
Good Luck!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Valued Mentor
TerryDotson
Message 3 of 7 (2,881 Views)
02-11-2011 03:37 PM in reply to: jclaidler
Simply draw a loose rectangle around your objects and use the BOUNDARY command, then erase the outer rectangles.
pendean
Message 4 of 7 (2,860 Views)
02-14-2011 05:55 AM in reply to: jclaidler
Like a WIPEOUT?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Mentor
jclaidler
Message 5 of 7 (2,853 Views)
02-14-2011 10:48 AM in reply to: jclaidler
Nope, not like WIPEOUT.  Easily stated, I need a line drawn around the outside edges of selected blocks.
New Member
kelley.pearson
Message 6 of 7 (2,251 Views)
08-16-2012 10:39 AM in reply to: jclaidler
Easy. Draw a closed polyline (rough) rectangle just outside your block or any object you want. Then use the BOUNDARY command with lsland detention. Choose Region or Polyline as Object type to create. Pick OK, then Enter if you do not want to select addition interal boundaries. Erase the orginal rough rectangle and outer boudary on it. You're left with your object plus the inner boundary shrinkwrap. No Lisp needed. Done! :smileyhappy:
New Member
jefferypsanders
Message 7 of 7 (1,282 Views)
09-24-2013 02:51 PM in reply to: jclaidler
I posted a cheap attempt at shrinkwrapping using the boundary command here:
http://www.jefferypsanders.com/autolisp.html
JPS
You are not logged in.
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
