CAD Managers
Active Member
SKSS
Message 1 of 10 (872 Views)
Settings for Drawing Status bar
872 Views, 9 Replies
09-26-2013 08:41 AM
Where are the settings for the drawing status bar saved?  (The ones that say Grid, Ortho, Osnap, etc...)  They don't seemed to be saved to workspaces or to profiles or to the cui.  I'm trying to set up a consistent UI for multiple users.
Thanks!
*Expert Elite*
JGerth
Message 2 of 10 (857 Views)
Re: Settings for Drawing Status bar
09-26-2013 12:13 PM in reply to: SKSS
Are you asking for settings for the _values_ stored and set by those controls, or settings as in what's displayed?
for many, if not all, the values are drawing specific.
Active Member
SKSS
Message 3 of 10 (851 Views)
09-26-2013 01:48 PM in reply to: JGerth
The settings for what's displayed.
*Expert Elite*
JGerth
Message 4 of 10 (831 Views)
09-27-2013 05:18 AM in reply to: SKSS
AFAIK, it's not documented, but would probably be registry entries only.
If you're on Subscription -- or ADN, that might be a good place to ask.
Active Member
SKSS
Message 5 of 10 (822 Views)
09-27-2013 06:33 AM in reply to: SKSS
OK.  Thanks!
*Expert Elite*
rkmcswain
Message 6 of 10 (791 Views)
09-29-2013 02:55 PM in reply to: SKSS
It's documented in the help files.
Find the system variable each button modifies (for example: F8 = Orthomode), then look up that sysvar.
They are either saved in the registry, drawing, or not saved at all.
Active Member
SKSS
Message 7 of 10 (778 Views)
09-30-2013 06:08 AM in reply to: SKSS
Thanks but I'm not looking for how to set the system variable, I'm looking for how to control the display of the status toggles.  For instance, we don't do 3D work in Cad so I would like to remove the 3D Osnap toggle from our standard UI.
**Master
dmfrazier
Message 8 of 10 (733 Views)
10-04-2013 08:42 AM in reply to: SKSS
For what it's worth, it appears they are stored in the registry.
For AutoCAD 2010, "vanilla" profile:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.0\ACAD-8005:409\Profiles\<<VANILLA>>\StatusBar\Application
For AutoCAD 2013, "vanilla" profile:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B001:409\Profiles\<<vanilla>>\StatusBar\Application
(I just searched the registry for "StatusBar".)
Active Member
SKSS
Message 9 of 10 (704 Views)
10-08-2013 12:46 PM in reply to: SKSS
That's the answer!  I can also find and edit that string in the .arg file. Thanks!
**Master
dmfrazier
Message 10 of 10 (701 Views)
10-08-2013 12:52 PM in reply to: SKSS
You certainly can (as an ARG file is essentially a renamed REG file).
As long as you import the edited ARG, the edits will take effect.
You are not logged in.
Announcements
Manufacturing CAD & IT Manager Resource
Additional information for installing, licensing & deploying Inventor, the Product Design Suites and Factory Design Suites.
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
