Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
See Classifieds for Dotsoft tool
12 REPLIES 12
Message 1 of 13
327 Views, 12 Replies
PDF importing tool announced earlier today.
$60 - sounds more like...
The Price is Right! 🙂
I've already suggested it to my new firm.
Don Reichle
"The only thing worse
than training your staff,
and having them leave is -
not training your staff,
and having them stay."
Courtesy Graphics Solution Providers
LDT-2K4
AMD Athlon 64 3200+ 2.2GHz
XPPro 32bit SP2
1GB RAM
Nvidia GeForce FX 5200 128MB
WD 36GB Raptor
12 REPLIES 12
Message 2 of 13
we'll have to check it out...8^)
jjd
"Don Reichle" wrote in message
news:5143871@discussion.autodesk.com...
Don Reichle
LDT-2K4
XPPro 32bit SP2
1GB RAM
WD 36GB Raptor
Message 3 of 13
Don Reichle said the following on 4/14/2006 7:00 PM:
Suggestion: Go ahead and get ToolPac.
PDF Import is included. That along with the new Image Bind command makes
it worth it. 😉
R.K. McSwain
http://rkmcswain.blogspot.com
Message 4 of 13
whats image bind do?
Dave
"R.K. McSwain" wrote in message
news:5143990@discussion.autodesk.com...
it worth it. 😉
R.K. McSwain
Message 5 of 13
David Allen said the following on 4/17/2006 4:31 PM:
http://www.dotsoft.com/toolpac.htm
Scroll down about 1/2 way to Image Tools, look just under there.
R.K. McSwain
Message 6 of 13
wow, what a trippy idea! Wonder how efficient that is...
R.K. McSwain
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
Message 7 of 13
On Tue, 18 Apr 2006 17:55:59 +0000, James Maeding
I'd say, um, not.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
Message 8 of 13
WOW! Did one person create Toolpac?
news:5145513@discussion.autodesk.com...
R.K. McSwain
Message 9 of 13
Matt Stachoni said the following on 4/18/2006 4:44 PM:
> I'd say, um, not.
Why?
R.K. McSwain
Message 10 of 13
>> I'd say, um, not.
>Why?
Well, I don't use ToolPac, but from what I understand, it creates a block of an
array of 2D solids that take on the color of the bitmap. Assuming 1 solid per
pixel, that would be several hundred thousand little tiny 2D solids.
It's possible that swatches of the same color could possibly be represented by a
larger solid, and possibly some sort of compression algorithm could be applied
such that you use fewer different color solids, but I'd like to see what kind of
file size one would get from this.
Matt
Message 11 of 13
> represented by a larger solid ...
Thats what the 'Optimization' option does. Also the background color is
ignored.
In our testing its very useful for logos, with exceptions like one sent
to us that was made of rendered spheres. It also seems to work very
well on mono scans of line drawings, especially small details.
While it will crunch a large grayscale aerial map, the resulting block
data makes the drawing too large because there are hardly ever any
adjacent pixels of the same color.
Images have their own set of problems, including transparency (on all
but mono images), the external file to track and send, etc. One could
argue the pluses/minuses of both approaches. We simply want to provide
a *choice* to the user.
As one of hundreds of tools. 🙂
Terry
Message 12 of 13
Thanks for the explanation.
I can easily see the value in such a tool (especially for small monochrome
logos), since Autodesk (for some reason) refuses to include images as part of
the DWG file's inclusive data set.
My question would be is it more efficient to use a bunch of 2D solids, or to use
hatching whose boundaries could be more than just 4 sides?
Matt
Message 13 of 13
> solids, or to use hatching whose boundaries could be more than just 4
> sides?
I see what your saying and will add that to the wishlist. There are
cases where the best solution is to simply use AutoCAD to manually trace
the outline of the image and hatch as necessary. That way you can use
splines, polylines, circles or ellipses as appropriate.
Its a time -vs- size/quality decision that has to be made by the user.
Terry
Administrator Productivity
