On Tue, 18 Apr 2006 22:17:15 +0000, R.K. McSwain wrote:
>Matt Stachoni said the following on 4/18/2006 4:44 PM:
>> I'd say, um, not.
>Why?
Well, I don't use ToolPac, but from what I understand, it creates a block of an
array of 2D solids that take on the color of the bitmap. Assuming 1 solid per
pixel, that would be several hundred thousand little tiny 2D solids.
It's possible that swatches of the same color could possibly be represented by a
larger solid, and possibly some sort of compression algorithm could be applied
such that you use fewer different color solids, but I'd like to see what kind of
file size one would get from this.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
