On Tue, 27 Mar 2007 20:39:16 +0000, DouglasJMeyer <> wrote:
>Yes yes he is, but then again, so am I.
>I take it this means something?
>I have not had a chance yet to try the other ideas, but I will do that first think in the morning.
>Thanks for all the ideas and I will let you know how it turns out.
The issue that I've seen is that, on dual monitor displays, AutoCAD cannot
always handle window coordinates effectively, particularly if they are
"negative" comared to the main window - e.g., you have AutoCAD on the right
monitor and the Open/Save dialog on the left.
ACAD holds the coordinates of the windows in the Registry (specifically, under
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\
\\Profiles\\Dialogs). For each dialog, there is
an X and Y value whose data specifies where onscreen the dialog box is, where
the upper left hand corner of the ACAD window is 0,0.
When ACAD gets confused about where a dialog box is, it will insert wacky
positive huge numbers for X/Y which will put your Open Save dialog roughly 5
states over.
With ACAD closerd, use REGEDIT to scan these Dialog entries (the Open/Save
dialog is named "Save Drawing As") and see if you see any X/Y values that are
WAY off the charts, and change them to 0/0. When you start ACAD, the dialog will
be at the top left corner of the AutoCAD window.
To keep yourself out of trouble, you need to follow some good multimonitor
habits. In the video driver, identify the displays and put Monitor #1 on the
left, and monitor #2 on the right. Keep AutoCAD's window on the left and put any
UI elements on the right monitor. Some video drivers allow you to specify not to
open subwindows on displays other than the primary application window.
Matt
mstachoni@comcast.net
mstachoni@bhhtait.com
