• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Active Contributor
    Accepted Solution
    Running Land Desktop 2008 with C3D 2012 under current subsription
    843 Views, 3 Replies
    02-08-2012 11:11 AM
    Is it possible to run Land Desktop 2008 with Civil 3D 2012 under the same subscription contract?
    Will Autodesk provide separate network license files or will a new 2012 version license file work for both?
    Thank you
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Running Land Desktop 2008 with C3D 2012 under current subsription
    02-08-2012 11:15 AM in reply to: mrobertson
    Subscription only allows for you to run your current release (2012) and up to three versions back (2009) only.  Your 2008 product, if upgraded thru Subscription has had its lease expired.  If you wish to file for an exception, you should probably contact your Reseller.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    *Expert Elite*
    JGerth
    02-14-2012 07:48 AM in reply to: TravisNave
     >>Your 2008 product, if upgraded thru Subscription has had its license revoked.
    FTFY - Since it's a perpeptual use license, not a lease.  The revocation is, as you correctly noted, a side effect of  upgrading, whether via subscritpion (which permits use of three versions back) or simple upgradinng..  A new purchase of 2012 would not result in the loss of the 2008 license, but a straight purchase would cost somewhat more than an upgrade from 2008 to 202.
    Active Contributor
    04-26-2012 02:55 PM in reply to: TravisNave
    With our resellers help we were able to get an extension to the end of the year.
    Thank you for the replies.
