• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    CAD Managers
    Valued Mentor
    jclaidler
    Remote Login: Install as Administrator
    183 Views, 21 Replies
    12-08-2009 06:42 AM
    I need to perform installations via remote, but the end user will not have admin rights. How can I remote in, then install utilizing my admin login? Edited by: jclaidler on Dec 8, 2009 2:42 PM
    _______________________________________________________________
    ITO - Application Management
    Factory Design Suite Ultimate 2012
    AutoCAD 2012 | Inventor Professional 2012 | Vault Professional 2012
    Please use plain text.
    Valued Contributor
    Re: Remote Login: Install as Administrator
    12-08-2009 03:47 PM in reply to: jclaidler
    I know this is not an answer to your question, so please excuse me. Will AutoCAD run without users having administration rights ? I know in previous versions, despite autodesk saying only power user rights were required, AutoCAD would have problems unless users had administrator privileges.
    12-08-2009 08:34 PM in reply to: jclaidler
    our IT Teams simply remote login to remote computers using their admin logins to install software and perform other admin related tasks on computers in remote offices
    Valued Mentor
    jclaidler
    12-09-2009 07:41 AM in reply to: jclaidler
    I wonder if they are doing anything extra? When I remote into another computer, the end user is logged in. They do not have admin rights, and mine will not carry thru to there computer.
    *Expert Elite*
    TravisNave
    12-09-2009 02:45 PM in reply to: jclaidler
    Right click setup.exe and Run as... Administrator or your domain credentials. Keep in mind that sometimes Autodesk will see an install done thru RDC as a violation to the EULA and it may prompt you with an error as such. Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    12-09-2009 06:34 PM in reply to: jclaidler
    the IT guys always ask us to logout before they remote login to do administrative things like install software etc...if they are doing a remote login to talk us through something they do not ask us to logout......so maybe thats the answer. loagout before they remote login
    Valued Mentor
    jclaidler
    12-10-2009 04:57 AM in reply to: jclaidler
    I have tried this, but we have the users locked down so much that option will not operate. There was a way thru the command prompt to allow an administrator to install software, but I can't remember what that was.
    Distinguished Contributor
    12-10-2009 05:10 AM in reply to: jclaidler
    you could try creating a batch file that runs up the installer & then launching the batch file on the machine.
    Some locked down networks are dumb enough to allow a batch file to run up applications with access to the reg (as batch files can been seen as access at an application level, not a user level).
    Time is an illusion, lunchtime doubly so
    *Expert Elite*
    TravisNave
    12-10-2009 12:47 PM in reply to: jclaidler
    Try not locking down the users so much. There's absolutely no excuse for having a user run as a restricted user. In fact, the only reason this problem exists is because someone in your company has a power trip. I mean no offense, but to me it is a sign of an incompetent IT staff. I deploy hundreds of computers in my enterprise and all of them have local administrator privilege. It is a requirement to install Autodesk software and it some cases even to run it. Many of the problems associated with the product could be avoided if IT stopped handicapping their users. The bottom line is, if you can't fix a problem that is caused by your users, then you have absolutely no business being in the MIS department. Restricting the user is not preventative maintenance. Provide the rights and the problem disappears. Enough said. I'll get off my soap box now. Everybody else can hold their applause.
    Travis Nave
    Valued Mentor
    jclaidler
    12-10-2009 12:49 PM in reply to: jclaidler
    We're a global company with about 5,000 AutoCAD users, with ONE IT department. Don't think thats going to be happening.
