Autodesk Technology Managers Forum
Share your knowledge, ask questions, and engage with fellow CAD/BIM Managers.
1104 Views, 4 Replies
Profile
All,
I have never really utilized profiles to set up autocad on multiple computers before. I recently created a company profile, exported it to a folder on the server. My problem is that when i import the profile and close autocad, it defaults to the original profile. How do i tell autocad to use my profile when ever it is opened?
Dave
4 REPLIES 4
AllenJessup
After you imported the Profile. Did you set it current?
You can also add the profile and or workspace to the target field of the icon used to start the program like this; C:\Program Files\Autodesk\AutoCAD Civil 3D 2012\acad.exe /nologo /p "C3D Metric 2.0" /w "C3D2.0"
Allen Jessup
Allen Jessup
CAD Manager - Designer
in reply to: AllenJessup
It only worked when I changed the shortcut, but by default the shortcut was telling it to use the civil 3d imperial profile. I thought about erasing the ext to the profile all together, but was afraid there would be un-foreseen consequences.
Thanks for the help,
David Martin
Draftsman
[PCS_Logo.gif]
Parsons Cunningham & Shartle Engineers, Inc.
1924 South Dan Jones Road | Avon, Indiana 46123
Tel 317.837.9900 | Fax 317.837.9925 | Cell 317.517.4561
DMARTIN@pcsengineers.com
________________________________
DISCLAIMER:
This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute, utilize, or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake, and delete this e-mail from your system. This transmission is intended for the recipient above and shall not be construed as official project information or direction except as expressly provided in the contract documents. E-mail transmission cannot be guaranteed to be secure or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message which arise as a result of e-mail transmission. If verification is required, please request a hard-copy version.
AllenJessup
If you're nervous about editing the shortcut. Make a copy of it first that you can revert to if you encounter trouble. But if you were using the shortcut that specified Civil 3D imperial. That would explain why you weren't getting your new profile.
Glad it helped.
Allen Jessup
Allen Jessup
Administrator Productivity
